WebMaximus
PC Specification: Intel Core i7 2700K, GTX 680, Win7 x64
Re: Action! 1.19.0
Fri Mar 21, 2014 6:35 am
For me the slider to adjust the level between system and microphone works just fine.
If you're only seeing this issue in Minecraft and Skype the problem seems to be with those titles rather than the slider in Action! don't you agree?
Laurent13
Re: Action! 1.19.0
Fri Mar 21, 2014 7:27 am
WebMaximus wrote:For me the slider to adjust the level between system and microphone works just fine.
You didn't understand what i'm talking about, slider works but we can not set the volume for the microphone to 100% and system sound to 100% we must do a choice 50/50 60/40 80/20 (unbalanced)
I want to do this !
Claunator
Re: Action! 1.19.0
Fri Mar 21, 2014 8:20 am
I want to do this !
The purpose of that slider is to set the sounds so that ur mic is loud enough to be heard without having to lower it later while u're editing. At least that's how i think it is. The system slider does NOT affect ur PC's volume in general, it's only for recording purposes. So yea, those 2 sliders are NOT about balance.
WebMaximus
Re: Action! 1.19.0
Fri Mar 21, 2014 9:37 am
Hmm...maybe I didn't understand this correctly then because I thought the slider was a way for you to not set the volume but rather decide the balance between the volume of the system sound vs the volume of the mic sound. This is also how it works for me when I've tested to use this slider, if I move the mic slider up to let's say 70 (which in turn will move the system sound slider to 30) the system sound will be much lower and my voice in the mic much louder when I then watch the recording. This is also exactly what the manual says, on page 35 you can read:
"AUDIO BALANCE
Audio balance controls the balance
between microphone and system
sounds. Adjust this option to record
clear live audio commentary."
Maybe someone from Mirillis can set us straight on this?
n3v3rm1nd
PC Specification: MSI GT60
Re: Action! 1.19.0
Fri Mar 21, 2014 6:03 pm
Starbound OpenGL recording is broken in this release. Rolling back to 1.18.0 .. Hud still not showing but Records on buttonpress. 1.19.0 shows the hud glitchy but doesnt record !
