Penx
PC Specification: windows 7 64 bit
Re: Live stream crashes Action!
Mon May 26, 2014 2:40 pm
That might be what the issue is for you. I never tried free streaming tbh.
But if you have a bought copy of Action! you can go here
http://client.mirillis.com/store/catego ... home_use-1
and buy a non commercial version of their streaming, it is only $3.00.
Saber
PC Specification: Windows 7 64bit
Mon May 26, 2014 11:18 pm
Well its not really free, its a full free trial of the software, and I know I could pay for a full trial but I'm not going to cough up the cash if I'm going to have the same issue currently going on. The Game I'm trying to stream to twitch is Marvel Heroes, and COD BO 2. I can play for either 10min or an hour and than Action, freezes/crashes on me. Now the only things I can think of is, my router can not handle the traffic, or the software is having an issues. I've contacted support twice with no reply yet.
Here is my speed test.
http://www.speedtest.net/my-result/3524880138
Penx
Tue May 27, 2014 1:32 am
Ahh that trial version, I had that before I bought Action! as well.
Support takes a while to get back, I went down that road too, my first email I sent in a month ago was marked as resolved for whatever reason.
But your upload speed might be the issue especially if you are trying to do it at high traffic times, I am not 100% on that. Very nice download though! :D
I can't say for sure that it is because it is the 'trial' version, it might also be the resolution you are trying at.
Since I don't know what you have done I am going to cram some things in here for you to try.
1. Stream at a lower resolution.
2. If you are streaming to twitch, get a new stream key.
3. Also if on twitch, have your dashboard open instead of your Channel.
4. Try not recording while you are streaming.
5. Disable everything that is not necessary for streaming.
If all else fails you can try what I did and reformat, but I don't recommend that fora program that you haven't even bought.
I hope one of these works for ya! let me know how it goes.
If all else fails PM and I can try to help you out.
Here is my speed test and i am able to stream at 720p no problem (I have dropped video a couple times, but it normally reconnects).
http://www.speedtest.net/my-result/3525022989
Saber
Tue May 27, 2014 11:12 pm
After getting a months subscription for the Live Stream, I'm still having the same issue. I've sent numerous support emails with no response. At this point of only owning this product for 4 days I want my money back. Support sucks with this company.
Wed May 28, 2014 11:27 am
Saber wrote:After getting a months subscription for the Live Stream, I'm still having the same issue. I've sent numerous support emails with no response. At this point of only owning this product for 4 days I want my money back. Support sucks with this company.
Please provide me your e-mail address in private message. I will check your ticket status.
SzikraTheDragon
PC Specification: Win 10 - FX-6330 - HD 7870 2GB - 8GB RA
Sun Aug 23, 2015 12:12 pm
I am having exactly the same symptoms right now. Did anyone find a solution?
