ToniRG
PC Specification: I7-3820, GTX 970, Windows 8.1 64 bit
Re: Error Action Nvencoder Nvidia drivers 352.86
Wed May 20, 2015 12:03 pm
Thank you, very good upgrade and finally works with Wolfenstein.
Mack
PC Specification: i7/GTX970/8GB/256SSD
Wed May 20, 2015 3:14 pm
after installing action_1_25_0 get this erroImage
have new nvidia drivers gtx970, W7 64 bit on version action_1_24_3_ have same problem like ToniRG
TommyP
PC Specification: Win 7 x64
Wed May 20, 2015 9:31 pm
radi wrote:Issue fixed in 1.25.0
DOWNLOAD HERE: http://bit.ly/ActionDownload
Thanks for the update, but why is there a reason not to let us choose where to install it? previous version let us choose where to install it, now it doesn't.
Ok something went wrong here, it doesn't overwrite my previous Action software but just install it Program Files (x86), when it's finished i get this weird error =>
O¿o
noahphense
PC Specification: i7, 980m, w8.1 standard
Thu May 21, 2015 2:16 pm
I am using the latest NVIDIA driver and Action 1.25.0.0 ..
Did this: http://forum.mirillis.com/viewtopic.php?f=36&t=36584
- np
TommyP
Thu May 21, 2015 3:02 pm
noahphense wrote:I am using the latest NVIDIA driver and Action 1.25.0.0 ..
- np
Gonna try your guide, but i used to uninstall both version and after that ccleaner to remove anything else, but i'll see the revo uninstaller never used it but heard about it
noahphense
Thu May 21, 2015 3:33 pm
- np
I live by them. On my old laptop, I had Windows 7 Pro installed since it came out until 4 months ago. Yeah, same registry. Nice and clean. heh
After you install CCleaner, you should take out the memory resident part. On this screen. Just uncheck stuff, etc..
monitoring
The key to keeping the computer clean is to use those two products all the time. Meaning, when you need to uninstall something, use Moderate on the Revo. Then reboot. Then use the CCleaner to clean the registry. As you know, not all applications have a nice 'uninstaller', meaning they leave a lot of crap behind in the reg.
Anyhow. GL
- np
