Not working for me. (Win 8.1 Pro)noahphense wrote:I don't believe I lost my "settings", but even if I did, they are easy to setup again.
The fix:
http://forum.mirillis.com/viewtopic.php ... =36584&e=0
Guess I'm the lucky one. They did email me this. But it was after I already found my own solution.TirexiHD wrote:Not working for me. (Win 8.1 Pro)noahphense wrote:I don't believe I lost my "settings", but even if I did, they are easy to setup again.
The fix:
support wrote:Hello,
due to technical reasons Action! have to be installed into default directory. Please try following steps below to completely re-install Action. You will need your serial number to activate your product again.
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - http://www.mirillis.com (if you have not purchased Action! through Steam).
Wait wait WAIT..noahphense wrote:Guess I'm the lucky one. They did email me this. But it was after I already found my own solution.TirexiHD wrote:Not working for me. (Win 8.1 Pro)noahphense wrote:I don't believe I lost my "settings", but even if I did, they are easy to setup again.
The fix:
4. Reboot your PC.
