noahphense
PC Specification: i7, 980m, w8.1 standard
Re: Fixed Action! 1.25.0.0
Thu May 21, 2015 5:00 pm
Yes, I suppose I don't understand. As I am not using W7. Everyone else that followed the steps in the fix have it working fine. So I guess yours is a one-off case.
And now, 1.25 does not allow you to select where to install it. So yeah, you'll be stuck with the default location until Mirillis decides to give you back that feature.
- np
As for still getting the error, sounds like you didn't run through the CCleaners registry portion, before reinstalling. Please see the original fix again. Step by step.
TommyP
PC Specification: Win 7 x64
Thu May 21, 2015 5:07 pm
There is a fix, turn on UAC then i can use Action!, but like i already said if i do that and reboot, then i get "Do you want to allow the following program to make changes to this computer" cause of turning the UAC on. But someday it would be fixed no worries :D
ps if you even read what i wrote then you know i did ccleaner
TommyP wrote:Hmmm, i uninstalled 1.25.0.0, with revo, then i reboot my computer, ccleaned, reboot again. But when i install 1.25.0.0 it still doesn't let me choose where to install and also still giving me the error 106 when trying to run the software when UAC is off ( i hate it)
noahphense
Thu May 21, 2015 5:09 pm
TommyP wrote:There is a fix, turn on UAC then i can use Action!, but like i already said if i do that and reboot, then i get "Do you want to allow the following program to make changes to this computer" cause of turning the UAC on. But someday it would be fixed no worries :D
It will only be fixed if you find the problem on your computer. It's not a problem with Mirillis.
Did you install Action with UAC on?
TommyP
Thu May 21, 2015 5:17 pm
How many times must i repeat myself?
Installation went fine even if it's not the "D:" ( driver that i want to be installed on) but on the 'C:\Program Files (x86)" (default path) but with UAC off i'm unable to use the software, then i get critical 106, and if i turn it on ( which i hate and don't want to use it) it let me be able to use it and for the not mirillis fault perhaps check http://forum.mirillis.com/viewtopic.php?f=36&t=36587 before saying it's not fault of mirillis... ;)
noahphense
Thu May 21, 2015 5:18 pm
UAC is your problem. Finish up with the support team.
Cheers.
TommyP
Thu May 21, 2015 5:20 pm
noahphense wrote:UAC is your problem. Finish up with the support team.
Cheers.
no it's mirillis problem cause 1.24 worked fine with UAC off :) and with 1.25 it doesn't
noahphense
Thu May 21, 2015 5:23 pm
Cheers.
There are others in this forum with UAC on, and their installs are working. So yeah, https://mirillis.com/en/company/contact.html ..
- np
TommyP
Thu May 21, 2015 5:33 pm
noahphense wrote:
Cheers.
- np
omg dude learn to read before replying...
TirexiHD
PC Specification: i7 5930k, 32GB DDR4, GTX1080, Win 10.
THX but not working.
Mirillis pls fix this problem.
<<<Rampage V Extreme - i7 5930k @ 4.5Ghz - 32GB DDR4 3000Mhz - MSI GTX 1080>>>
noahphense
Thu May 21, 2015 5:40 pm
TirexiHD wrote:THX but not working.
They're not really chiming in... so yeah.. contact support.
Cheers.
- np
