Denvxr wrote:To all who need help with this. I found a solution and unfortunately since the mirillis team fails to help. I found my own way and it works... Pretty much what you need to do is set the priority of action to high or above normal in your task manager. That solved the problem for me. To the mirillis action team, please respond to needy customers quicker
When I try to do this, my PC says I do not have permissions to do it. I can set the Update speed in the Task Manager's View tab, but I don't think this is the solution.
Please help! It's been months since I've purchased Action, and it's unusable in this state.
Processor Intel(R) Core(TM) i5-4570 CPU @ 3.20 GHz
Memory (RAM) 8.00 GB
Primary hard disk 174GB Free (466GB Total)
Manufacturer ASUS motherboard
Total amount of system memory: 8.00 GB RAM
System type: 64-bit operating system
Number of processor cores: 4
Display adapter type: NVIDIA GeForce GT 640
Total available graphics memory: 4095 MB
Dedicated graphics memory: 2048 MB
Dedicated system memory: 0 MB
Shared system memory: 2047 MB
Display adapter driver version 9.18.13.1106
Primary monitor resolution 1920x1080
DirectX version DirectX 10
