hornby7590
PC Specification: Nvidia GTX 760 X 2 i7 2700K
Re: Action! doesn't show video in Sony Vegas
Fri Nov 06, 2015 6:23 pm
this needs sorted fast, its a disgrace for a paid product to ave this fault for this amount of time!!
PepperBelly
PC Specification: Intel Core i5 2500k, GTX 770, Windows 7
Thu Nov 12, 2015 1:16 am
hornby7590 wrote:this needs sorted fast, its a disgrace for a paid product to ave this fault for this amount of time!!
Agreed. I'm running out of patience at this point. There has been 3 updates since I last posted, none of which included a fix. It isn't something that's too difficult to rectify, considering it worked in the past, and OP showed that it's simply a broken container for the MP4. There's no excuse for it not being fixed after all this time (dating back several months). I paid for a product that worked flawlessly. Then after a few updates, it broke, and is now unusable for me and many others.
Please. Just. Fix it.
hej
Tue Nov 24, 2015 4:37 am
Please fix this is making me upset I am not sure at this point if ctrl+del saves me more time than sorting through the videos manually and recording with bandicam but not having any problems during production.
Claunator
Tue Nov 24, 2015 8:17 pm
To the OP, that's the EXACT problem i had with Timeshift with EVERY version from 1.27.0 onwards!
PepperBelly
Fri Nov 27, 2015 2:28 pm
Still waiting...
hej
Mon Dec 07, 2015 4:54 am
Claunator wrote:To the OP, that's the EXACT problem i had with Timeshift with EVERY version from 1.27.0 onwards!
It still doesn't work? :?
PepperBelly
Mon Dec 07, 2015 8:01 pm
Considering how long it's taking for the next update, I sincerely hope that a fix is included in it.
hej
Mon Dec 28, 2015 8:32 am
Will this ever be fixed or am I better off begging badicam for a ctrl+del feature?
PepperBelly
Fri Jan 01, 2016 5:39 am
Yeah... this is taking a ridiculously long time to resolve.
Surfer9x
PC Specification: Intel i7, Nvidia GT540M 2GB, Win 10 64
Wed Jan 20, 2016 10:55 am
I have also paid for a product that worked smoothly at first, but since the latest updates and from Windows 10, things have worsened.
1. There are many synchronization problems when recording at 60fps.
2. There are problems loading the video Sony Vegas, and the solution given is not correct.
3. Also recording is not entirely smooth as before, there are sometimes lag.
Many problems have not been resolved and that took months trying to solve with the support department, but there is no solution, I'm tired and I had to reinstall Dxtory to record perfectly, until there is no solution, I stopped Mirillis use.
