ace11 wrote:any tip how to bypass this problem for now ? ( until splash update to 1.2)
plz ?
remux the mkv with older mkvmerge (3.x is safe, 4.1.0 perhaps) or take the newest verion and select in all track settigns "header-conpression" none
plz ?
So, it is not fixed at all. Splash simply still doesn't support header removal compression.Joco1114 wrote:With 1.2.1 Pro I can play sound of all MKVs, but it cant play movies smoothly for me.
I did some files with mkvtoolnix 4.1.1 with zlib comp for audio, video etc.BDX wrote:So, it is not fixed at all. Splash simply still doesn't support header removal compression.Joco1114 wrote:With 1.2.1 Pro I can play sound of all MKVs, but it cant play movies smoothly for me.
Newest mkvmerge 4.3.0, AVC/H.264 for video track and AC3 or DTS for sound track, all default settings.Terry wrote:I did some files with mkvtoolnix 4.1.1 with zlib comp for audio, video etc.
works fine here.
whats your settings?
Thanks for clearing the problem. Hope next Splash version will open all MKV files without any issuesHelios wrote:Hi all,
Splash Lite 1.5.0 and Splash PRO 1.2.1 updates didn't cover all MKV compression tools.
Its my fault, really sorry for inconvenience :/
New fix waits for neerest release, whitch we plan soon.
regards,
It's nice to hear this. Thank you very much and thanks for the great product!Helios wrote:Hi all,
regards,
