xtrips
PC Specification: Core2Duo 2.4Ghz,nVidia 8600GTS,Win7 x86
Re: Sound over HDMI problem
Tue Aug 24, 2010 6:44 pm
Guys, I know you wanna help, but this is just complicating things.
Me and others here as I see have an HDMI soundcard capable of bitstreaming.
Bitstreaming means digital signal encapsulated in codec as opposed to LPCM which is raw digital signal.
At the other end, if we mean bitstreaming, so we do have devices capable of decoding these codecs.
Now, the problem is simple: SplashPro doesn't see any of it and the option is grayed out.
Will SplashPro support bitstreaming or not?
icsterm
Contact: Yahoo Messenger
Tue Aug 24, 2010 7:45 pm
It might be a problem capturing the driver as bitstream compatible.
Joco1114
Thu Sep 09, 2010 4:45 pm
icsterm wrote:It might be a problem capturing the driver as bitstream compatible.
I solved the problem digital bitstream on my Xonar. I have downloaded the unified driver. Its just in beta phase, but working correctly for me. In this driver I can swith between analog and S/PDIF. S/PDIF has PCM, Dolby Digital Live and DTS Interactive selections. I selected PCM.
In the Splash just use S/PDIF bitstream (it didnt work with HDMI bitstream) and everything will working correctly.
Here are some pictures and links:
Universal driver: http://brainbit.wordpress.com/category/uni-test-builds/
Sorry, the Xonar driver reads my national language, thats why its not english but hungarian.
Home Theater:
Synology NAS 1010+ | 9TB HDD
Sun Apr 10, 2011 10:23 pm
PLease check if this problem is solved with latest Splash PRO version.
