Nielo TM
Re: A few important features are still missing.
Tue Sep 14, 2010 9:16 pm
It's not lossless. A true lossless scaling can only done via integer. I suppose it is possible to work within a threshold. So the user doesn't notice the erorrs.
Joco1114
Wed Sep 15, 2010 4:42 am
Exactly.
Home Theater:
Synology NAS 1010+ | 9TB HDD
BorisVasilev
PC Specification: Windows 7 Ultimate x64
Fri Sep 17, 2010 11:17 am
I don't care about fine details. I want my whole screen to show my movies and I don't want to have all details on the left and right lost. And I can't notice any difference with CyberLink TrueTheater Smart stretch turned on. They can add smart stretch as additional option and leave the zoom feature for those who would like to use it.
Come on, there are just few more steps and you're gonna shoot PowerDVD. Don't you want to be the best?
crl2007
Fri Sep 17, 2010 3:43 pm
There is still that annoying bug when you have multiple files in one folder. The first movie has subtitle, but when the second starts, the subtitle does not load. This is from the first version of Lite. There is no chance to fix this annoying bug ?
BorisVasilev
Fri Sep 17, 2010 6:31 pm
Are you sure you have the "Automatically load subtitles from file" setting on?
crl2007
Fri Sep 17, 2010 7:37 pm
No, in all this multitude of settings, such a checkbox can be overlooked. In 1.2.2 the problem is fixed. This bug was since the first lite release, not just now.
Tue Sep 21, 2010 4:14 pm
gmit wrote: That's not really true since smart algorithms will scale unfocused objects/background, while leaving focused objects intact.
I got it and it is interesting, however does not look like "a task for a day".
Will put in on our suggestions list.
BorisVasilev
Wed Sep 29, 2010 11:15 pm
Also, a graphical equalizer and flv support is missing. Would we see such features in some of the next releases?
