turkey2008abc
PC Specification: win7 intel 4500m
Re: Splash Lite 1.6.0 & 1.6.1
Sun Jan 02, 2011 10:45 am
thanks for turkish language
Roobaj
PC Specification: Windows 7 64bit
Sat Jan 29, 2011 12:56 pm
Can you guys please add file re-association under control panel --> default programs --> set your default programs in Windows vista/7?
For me, this is the only thing missing from this amazing player.
dvetreti
PC Specification: Phenom 9500, ATI 4850, XP SP3
Mon Feb 21, 2011 8:56 pm
Why don't the special effects subtitle ass??? :(
janek 77
PC Specification: t3200 intel 4500 MHD Win Vista Basic
Tue Mar 08, 2011 2:05 pm
There is a problem with the choice of subtitles for users of your product in Poland.
I cannot see subtitles in the form of sub stream in DVB-T.
Apparently your program is not fully consistent with DVB-T specification.
Please adress the issue and correct the problem.
The use of DVB-T in Poland is expanding and it would be nice to adapt your program to such a big market.
Looking forward to your answer
Regards
vjott
PC Specification: Athlon M300, Mobility Radeon 4100, Win 7
Wed May 18, 2011 9:29 pm
Excellent player, only a few steps behind the popular free ones like KMplayer, VLC, PotPlayer, Zoom Player and the likes. Four things though:
(1) No support for styled subs embedded in MKVs, (they all play with a plain font defined in the settings and not with the embedded font style)
(2) No support for OGM
(3) Crashes everytime when skipping to the next file in a playlist
(4) No setting to automatically resize the application window, based on video size.
Apart from those 4 hiccups, the interface is excellent, seeking is quite accurate, performance is great and most files are supported.
