P.J
Re: 24 Bugs and Enhancements
Sat Jul 30, 2011 2:38 pm
7) Every good media player refreshes the movie while dragging the mouse over the timeline with pressed mouse button. Why the Splash PRO updates the movie only after releasing the mouse button?
WMP12 doesn't do it too, Not good!
8) In case I disable the Loop feature, the movie should be paused at the last frame at the end of the playback.
It must stop the video, means unload the file, Not good!
10) Click to the movie screen should work as a pause/play while the double click should still work as enable/disable fullscreen. The best implementation is in MPC: If you double-click to the movie which plays, the first click pauses the movie and the second click starts the movie in a fraction of the second while enabling/disabling the fullscreen mode.
Pause/Play: Only Space key or the buttons.
Double-click: Fullscreen.
It's Splash not MPC, so Not good!
11) It would be nice to allow users to drag the player window while dragging by the movie screen.
Really bad idea. Splash team must remove it :(
Drag and Drop should be for ONLY the top window bar.
16) If you open a movie in the movie player, its window size should be automatically resized to display the movie in 100% (1:1).
The worst idea!
19) Pressing the ESC key in window mode should pause the playback and minimize the player (like in GOM).
ESC shouldn't do anything. It should be Space key to pause/play.
Minimize? Again, it's Splash not GOM.
22) In GOM player, I often press space and enter keys simultaneously to enable fullscreen and start playback OR to disable fullscreen and pause playback. Both keys works in Splash PRO player but for an unknown reason, pressing both keys at once will only accept the first key.
Space+Enter should do ONLY Fullscreen/De-fullscreen. In Splash, they added Enter key to do it too, so no problem ;)
Space Key = Play/Pause
24) Often, if I drop a new movie into the SplashPRO player, the movie is played smoothly but for the first seconds without audio and the player is unresponsive. After few seconds the players will start responding normally.
EXACTLY! It's a bug that still exists in v1.10.0 :cry:
Anyway, thanks for your feedback :)
Thu Aug 11, 2011 12:01 am
P.J wrote:...
Can you provide some more info why this is not handy in your case?
This should not be a problem for a user as it does not interfere with any other functionality.
P.J
Wed Aug 17, 2011 1:16 pm
Not important but it's windows based program.
Even in photoshop (a editing program not a player), you have to use Hand tool not with the cursor.
Just my two cents :D
Sun Aug 21, 2011 7:54 pm
P.J wrote:Not important but it's windows based program.
Yes, beacause with cursor in Photoshop you usually perform some actions (brush, dodge, eraser etc).
There is no function in Splash that it could interfere with.
P.J
Sun Aug 21, 2011 11:32 pm
Oh, found it, "0" key :D
The thing I needed to reset size and position :)
qwerty
Mon Aug 22, 2011 3:21 pm
Splash (Lite and Pro) have problem with high resolution movie:
Sample -
Fix it!
Edit: Please add support of wtv format (record from Windows Media Center). Codecs support, but not container format.
P.J
Thu Aug 25, 2011 9:13 am
The links don't work.
qwerty
Thu Aug 25, 2011 2:45 pm
Ok.
1st sample: you can download from http://www.youtube.com/watch?v=-9sc7gxavDc
2nd sample: http://www.youtube.com/watch?v=z5zI_6oT0Mc
(use Easy Youtube Video Downloader for firefox or what ever you want to download original MP4).
Other bug: I have 720x432 (1,(6)) movie. It's close to 16:9 format (1,(7)), but splash think it's a 4:3 format (1,(3)).
P.J
Thu Aug 25, 2011 9:30 pm
Splash doesn't support higher resolution than 1080p.
@Second problem: Can you upload it?
You can try to change Display Format to Zoom or else to see the difference.
qwerty
Fri Aug 26, 2011 10:24 am
Yes, I can change option, but resize 2 16:9 format - splash don't keep original aspect ratio.
Here is sample (I cut audio): http://www.mirrorcreator.com/files/1NSS ... .avi_links
Return to “General Topics”
