tecram
PC Specification: Athlon 4850e (2.4 Dual Core), ATI HD3200
Re: System requirements for Picture2.
Fri Nov 19, 2010 6:11 pm
icsterm wrote:Any AMD x3 or x4 CPU should work fine because Splash PRO is multi-core optimized.
Thanks one more time. I'm interested in AMD CPUs for 1080p with very high bitrates (MKV and BD bitrates).
sensei wrote:Like I said, on my pc everything works smoothly (720p/1080p) with Picture2 ON.
Phenom II 555 is one of my favorites. I would like to know if Athlon II X4 is sufficient (I suspect yes). There are 605e, 610e and 615e models with 45W energy-efficient that I'm considering.
Greetings.
sensei
PC Specification: i5-7200U, 8GB RAM, Win 10 x64
Fri Nov 19, 2010 6:59 pm
Greetings.
With good motherboard you can unlock two cores in Phenom II 555 (work as quad), read about it.
icsterm
Contact: Yahoo Messenger
Sat Nov 20, 2010 6:51 pm
sensei wrote:
Greetings.
Choose Asus or Gigabyte, read the user reviews about unlocking AMD cores. Also make sure the CPU revision matches.
