icsterm
Contact: Yahoo Messenger
Re: setup.exe unsafe?
Fri Nov 19, 2010 12:01 pm
Joco1114 wrote:I checked and downloaded it again. My size is 14,498,520 bytes.
Try this direct link: http://mirillis.com/files/splash_pro_1_3_2_setup.exe
After downloading the file, try uploading it to www.virustotal.com and make a full scan.
If it comes clean you can safely disable your AV software and install Splash.
