impreza0109
PC Specification: i5 3570k, RTX 2070 Super, W10
Re: Subtitle Fix
Sun Dec 20, 2020 7:10 am
jlnsrk wrote:
Fri Nov 08, 2019 5:08 pm
Hello Mirillis Team,
so I have been having an issue with Splash Player for quite some time now. The subtitles of some Anime would not be shown properly. To remedy this I made a plugin for your tool whose effect can be seen in the following attachments.
Before:
After:
I would like to make my tool available to other people in binary form, however I understand that Splash Player is 100% the property of Mirillis and hence I would like to ask your permission before I do this to prevent any kind of issue from occurring from me having done this work.
I am attaching this code in case you guys would like to review it.
Code: Select all
#include <Windows.h>
#include <TlHelp32.h>
#include <intrin.h>
typedef int (__cdecl* Type_InitSubtitleFont)( wchar_t *Str, int, int, int, int, int, int, int, int );
Type_InitSubtitleFont pInitSubtitleFont;
int __cdecl hkInitSubtitleFont( wchar_t *Str, int a1, int a2, int a3, int a4, int a5, int a6, int a7, int a8 ) // D3D12
	int Len = wcslen( Str );
	int SkipIndex = 0;
	for( size_t i = 0, j = 7; i < Len && j > 0; i++ )
		if( Str[i] == ',' )
			if( j < 2 )
				SkipIndex = i + 1;
			j--;
	return pInitSubtitleFont( &Str[ SkipIndex ], a1, a2, a3, a4, a5, a6, a7, a8 );
typedef int( __cdecl* Type_RenderSubtitleLine )( HDC hdc, wchar_t* Str, int a3, int a4, int a5, int a6, int a7, int a8 );
Type_RenderSubtitleLine pRenderSubtitleLine;
int __cdecl hkRenderSubtitleLine( HDC hdc, wchar_t* Str, int a3, int a4, int a5, int a6, int a7, int a8 )// GDI
	int SkipIndex = 0;
		if( Str[ i ] == ',' )
			if( j < 2 )
				SkipIndex = i + 1;
			j--;
	return pRenderSubtitleLine( hdc, &Str[ SkipIndex ], a3, a4, a5, a6, a7, a8 );
bool bDataCompare( const BYTE* pData, const BYTE* bMask, const char* szMask )
	for( ; *szMask; ++szMask, ++pData, ++bMask )
		if( *szMask == 'x' && *pData != *bMask )
			return false;
	return ( *szMask ) == NULL;
DWORD dwFindPattern( DWORD dwAddress, DWORD dwLen, BYTE *bMask, char * szMask )
	for( DWORD i = 0; i < dwLen; i++ )
		if( bDataCompare( ( BYTE* ) ( dwAddress + i ), bMask, szMask ) )
			return ( DWORD ) ( dwAddress + i );
	return NULL;
void *DetourFunc( BYTE *src, const BYTE *dst, const int len )
	BYTE *jmp = ( BYTE* ) VirtualAlloc( nullptr, len + 5, MEM_COMMIT, PAGE_EXECUTE_READWRITE );
	DWORD dwback;
	VirtualProtect( src, len, PAGE_READWRITE, &dwback );
	__movsb( jmp, src, len );
	jmp += len;
	jmp[ 0 ] = 0xE9;
	*( DWORD* ) ( jmp + 1 ) = ( DWORD ) ( src + len - jmp ) - 5;
	src[ 0 ] = 0xE9;
	*( DWORD* ) ( src + 1 ) = ( DWORD ) ( dst - src ) - 5;
	VirtualProtect( src, len, dwback, &dwback );
	return ( jmp - len );
DWORD __stdcall dwThread( void* )
	HMODULE hmModule = GetModuleHandle( nullptr );
	IMAGE_DOS_HEADER* pDosHeader = reinterpret_cast< IMAGE_DOS_HEADER* >( hmModule );
	if( pDosHeader->e_magic != IMAGE_DOS_SIGNATURE )
		MessageBoxA( 0, "Error 1", nullptr, 0 );
		return 0;
	IMAGE_NT_HEADERS* pImageNtHeader = reinterpret_cast< IMAGE_NT_HEADERS* >( ( ( DWORD_PTR ) hmModule + pDosHeader->e_lfanew ) );
	if( pImageNtHeader->Signature != IMAGE_NT_SIGNATURE )
		MessageBoxA( 0, "Error 2", nullptr, 0 );
		return 0;
	DWORD dwSize = pImageNtHeader->OptionalHeader.SizeOfCode;
	DWORD dwStart = ( DWORD ) hmModule + pImageNtHeader->OptionalHeader.BaseOfCode;
	DWORD dwAddress = dwFindPattern( dwStart, dwSize, ( BYTE* ) "\x57\x56\x55\x53\x81\xEC\x00\x00\x00\x00\x8B\xB4\x24\x00\x00\x00\x00\xBB\x00\x00\x00\x00\x83\xFE\x00\x0F\x44\x9C\x24\x00\x00\x00\x00\x8D\x84\x24\x00\x00\x00\x00\x50", "xxxxxx????xxx????x????xxxxxxx????xxx????x" );
	if( !dwAddress )
		MessageBoxA( 0, "Error 3", nullptr, 0 );
		return 0;
	pInitSubtitleFont = ( Type_InitSubtitleFont ) DetourFunc( ( BYTE* ) dwAddress, ( BYTE* ) hkInitSubtitleFont, 0xA );
	if( !pInitSubtitleFont )
		MessageBoxA( 0, "Error 4", nullptr, 0 );
		return 0;
	dwAddress = dwFindPattern( dwStart, dwSize, ( BYTE* ) "\x57\x56\x55\x53\x83\xEC\x4C\x8D\x04\x24\x50\xFF\x35\x00\x00\x00\x00", "xxxxxxxxxxxxx????" );
	if( !dwAddress )
		MessageBoxA( 0, "Error 5", nullptr, 0 );
		return 0;
	pRenderSubtitleLine = ( Type_RenderSubtitleLine ) DetourFunc( ( BYTE* ) dwAddress, ( BYTE* ) hkRenderSubtitleLine, 0x7 );
	if( !pRenderSubtitleLine )
		MessageBoxA( 0, "Error 6", nullptr, 0 );
		return 0;
	return 1;
extern "C" BOOL __declspec( dllexport ) __stdcall EnumProcesses( DWORD *lpidProcess, DWORD cb, LPDWORD lpcbNeeded )
	PROCESSENTRY32 pe32;
	HANDLE hProcessSnap = CreateToolhelp32Snapshot( TH32CS_SNAPPROCESS, 0 );
	if( hProcessSnap == INVALID_HANDLE_VALUE )
		return FALSE;
	pe32.dwSize = sizeof( PROCESSENTRY32 );
	DWORD dwNeeded;
	if( lpcbNeeded == nullptr )
		lpcbNeeded = &dwNeeded;
	*lpcbNeeded = 0;
	if( Process32First( hProcessSnap, &pe32 ) )
		do
			if( lpidProcess )
				lpidProcess[ *lpcbNeeded ] = pe32.th32ProcessID;
			*lpcbNeeded++;
		while( cb / sizeof( DWORD ) > *lpcbNeeded );
	return *lpcbNeeded > 0;
extern "C" DWORD __declspec( dllexport ) __stdcall GetModuleBaseNameW( HANDLE hProcess, HMODULE hModule, LPWSTR lpBaseName, DWORD nSize )
	MODULEENTRY32 me32;
	HANDLE hProcessSnap = CreateToolhelp32Snapshot( TH32CS_SNAPMODULE | TH32CS_SNAPMODULE32, GetProcessId( hProcess ) );
		return 0;
	me32.dwSize = sizeof( MODULEENTRY32 );
	if( Module32First( hProcessSnap, &me32 ) )
		do
			if( me32.hModule == hModule || me32.modBaseAddr == ( BYTE* ) hModule )
				lstrcpyW( lpBaseName, me32.szModule );
		while( Module32Next( hProcessSnap, &me32 ) );
	return 0;
BOOL APIENTRY DllMain( HMODULE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
	switch (ul_reason_for_call)
	case DLL_PROCESS_ATTACH:
		CreateThread( nullptr, 0, reinterpret_cast< LPTHREAD_START_ROUTINE >( &dwThread ), hModule, 0, nullptr );
	case DLL_THREAD_ATTACH:
	case DLL_THREAD_DETACH:
	case DLL_PROCESS_DETACH:
		break;
	return TRUE;
Cheers.
Sorely need this feature to work as well
Saunders
PC Specification: i5 4440, R9 290, 16GB ram Windows 10
Re: Subtitles Issue
Tue Oct 19, 2021 1:22 pm
I have identical problem. I get some random characters when these leathers appear: Č, Ć, Đ, Š, Ž
They are from "Serbian Latin" keyboard
gadstrikeph
PC Specification: Ryzen 5 5600X, RTX 3060, Win11
Re: Subtitles Issue
Mon Oct 21, 2024 5:46 am
Man. Am getting the same problem as well. Sorry to resurrect the thread. But really getting desperate on getting this issue fixed.
Return to “Splash 2.0”
