Re: Action! Crashes When Starting Recording
Tue Jan 10, 2023 7:33 am
Your Dxdiag report shows that the process called Recorder.exe is crashing (it is not Action! process). Maybe it is causing Action! to close/crash.
Is there another screen recorder running in background? Try to uninstall this Recorder.exe and see if that helps.
Eisdax
PC Specification: IntelCorei7960/NvidiaGeForceGTX960/Win10
Fri Jun 09, 2023 9:00 pm
It's June,... and still no reply to my issue.
Mirillis Action still crashes when it tries to save the recording of an area,.... or when I try to save any kind of recording. "Game" recordings will not play properly, it only records the first second and than will crash.
What is the issue here?
It is on the latest version.
Everything is updated on my PC.
What is the cause of this?!
