Gustavo
PC Specification: 1080ti , i7 7900k, 16gb RAM, z390. W10.
Re: Hardware Acceleration
Tue Jul 27, 2021 5:40 pm
Gustavo
Fri Jul 30, 2021 11:43 pm
it is frustrating that there is no one to fix the problem.
with the brilliant minds that must be here
Watchman
Tue Aug 03, 2021 5:57 pm
Hi Gustavo,
This is one of the most bizzare problems in a long time. We are still trying to reproduce it on our side :(
Gustavo
Tue Aug 03, 2021 9:19 pm
Hi Gustavo,
Thank you very much for your interest!
I would be eager to know what the problem is.
I have more information, when I activate the record tab on the hard disk, at the same time I broadcast on twitch, it also looks black on the hard disk of the PC.
Say it only happens to me with Twitch.
I did a PC format, in case the problem was mine, but everything remains the same.
Gustavo
Tue Aug 03, 2021 10:52 pm
Gustavo
Sat Aug 21, 2021 4:26 pm
I can only say:
Many thanks to the team behind Action Mirillis!
bug fixed, it can now be broadcast on twitch.
Yesterday I received a message by mail, that they had already solved it, that today there was going to be an update.
And effectively it has been like that.
After a long time of work, investigating, you have found the cause of the error, and that makes you great, because it was not an easy task.
I realize the professionalism and level of recognition that the Mirillis team has.
1000 thanks !!
It was a god level problem 😅, so you can be proud!
an affectionate greeting from me.
Users browsing this forum: leopeck and 22 guests
