Yea. Yea. Yes... Yes: NOW IT'S WORKING!
... Please fix this, I'm happy I can record the game now, but...
I would really appreciate to use Mirillis Action while the "ENB-graphic-mod" is installed on Resident Evil 5.
Thank you very much.
We will check this but I remember a fix for SweetFX a looong time ago and it worked. Guess we need to verify this again.bKay wrote: ↑Sun Aug 01, 2021 12:11 pmI think I know what's causing the issue.
I just google "Resident Evil 5 Mirllis Action enb", then I found a thread (created in this forum), that ENB-mods and SweetFX aren't really get along with Mirillis Action.
People were asking for a fix, that was in 2013, did anything changed since then?
That would explain why the disk version (the originally without graphic mods), was connected probably with Action, but the Steam version, which has the mod installed, is not...
I will try to remove the mods and give it another try, if it doesn't work... then I'm just gonna give up on it.
We will do our best to make it work.
In the folder there is a file called "re5dx9.exe",; it's basically the game, which is launched once you press "play" on Steam.
