alicesphere
PC Specification: AH Window 11 Pro
Re: Issue Connecting Twitch Account in Mirillis Action
Thu Mar 12, 2026 10:51 am
I had something similar happen a while ago. In my case the OAuth login window wasn’t completing properly, so Action never received the confirmation from Twitch.
A couple things you could try:
Log out of Twitch in your browser, then try connecting again from Action.
Temporarily disable browser extensions (especially ad blockers) if the login window opens through your default browser.
Check in your Twitch settings → Connections and remove any old Mirillis/Action authorization, then reconnect.
If it still doesn’t work, using the manual stream key is a good workaround and usually works without issues.
selenamoha
PC Specification: CPU model
Tue Apr 21, 2026 6:38 am
This seems like a frustrating integration issue. If standard fixes don’t work, using the manual stream key is a practical workaround. Also worth checking Twitch API changes or waiting for a software update.
https://clickergamesaz.io
selenamoha
annehathaway wrote:
Thu Sep 04, 2025 4:22 am
Hi everyone,
I’m having trouble connecting my Twitch account to Mirillis Action. Although I can log into Twitch via browser without issues, Action’s Accounts Manager won’t complete the login and keeps showing me as “not connected.”
YouTube streaming works fine.
I’ve updated to the latest version, reinstalled the software, and double-checked my network—no change.
I also tried re-adding the account and checking for firewall/antivirus conflicts.
Has anyone else faced this with Twitch integration? Is there a known fix, or should I use the manual stream key as a workaround?
Many thanks for considering my request.
Connection issues like this can be frustrating. Since basic troubleshooting hasn’t worked, using the manual stream key is a solid workaround while waiting for a fix or official update from developers.
nytwordlehints
PC Specification: i7 13700k
Wed May 20, 2026 11:54 am
The suggestion to manually enter the stream key is very practical and helpful!
Return to “General Topics”
