Uninstall and install didn't work. Tried to delete all references on the harddisk and in the registry but to no avail.
Please help as I now can't watch HD-movies on my laptop anymore
Is there some way to enable logging?
It's the same error. I guess that Splash checks for hardwaresupport or something like that at the startup and it crashes doing so. And I guess the culprit is the videodriver. Because 1.3 worked fine on my laptop and after a while it stopped working, so I guess an updated driver (Windows Update) changed something that Splash can't cope with.NumB wrote:Splash Lite 1.4.0 not working. Gives Don't Send message...
If i run it as administrator gives this: 'Critical error during initialization' - 'The application cannot be executed'
you mean a downgrade for my video card driver will perhaps solve this issue?latino wrote:It's the same error. I guess that Splash checks for hardwaresupport or something like that at the startup and it crashes doing so. And I guess the culprit is the videodriver. Because 1.3 worked fine on my laptop and after a while it stopped working, so I guess an updated driver (Windows Update) changed something that Splash can't cope with.NumB wrote:Splash Lite 1.4.0 not working. Gives Don't Send message...
I just tried that now, went back to the WDM 1.1 driver from MS, but it still doesn't workNumB wrote:you mean a downgrade for my video card driver will perhaps solve this issue?latino wrote:It's the same error. I guess that Splash checks for hardwaresupport or something like that at the startup and it crashes doing so. And I guess the culprit is the videodriver. Because 1.3 worked fine on my laptop and after a while it stopped working, so I guess an updated driver (Windows Update) changed something that Splash can't cope with.NumB wrote:Splash Lite 1.4.0 not working. Gives Don't Send message...
