Nielo TM
Re: Splash PRO 1.5.0
Sat Feb 26, 2011 3:53 am
Yes it is an excellent update.
aminnazifi
PC Specification: amd athlon II X4 , Ati 3870 . win7x64sp1
Sat Feb 26, 2011 9:15 am
great update thank you , thanks for adding mpg1 support . but in mpg1 formats when i jump forward at a specific time screen will jumping badly just in mpg1 files.
please add flv support too thank you so much for your great player ever!
aspireseries
PC Specification: Windows 7 x64, ATI Radeon 5570
Sat Feb 26, 2011 12:04 pm
I have used Splash Pro 1.4.1 till now and previous versions too and the speed was remarkable. Since this update to 1.5.0 it works very slow (don't know for sure if GPU decoding is working anymore) and also seeking takes 2-3 s... with stuttering and lags.
tuvi123
Sat Feb 26, 2011 6:32 pm
Great update but you did not add the must-have improvements.
some suggestions:
SUBTITLES:
1) BOLD subtitles.
2) IDX/SUB format support, it's MUST-have - a lot of subtitles come in IDX+SUB format and Splash simply can't view them.(they take advantage of all options of Vsfilter/Directvobsub by Gabest)
3) ADD the option to change subtitle size by numbers (and not only by the pre-defined sizes).
4) ADD the option to prefer external subtitles over internal (like if MKV has eng internal subtitle and external fr srt subtitile - it will load the external and not the internal if the option is checked in the settings)
VIDEO:
1) ADD FLV support (if it will not possible dut to license problems then please add option to use external decoder for FLV to be used withe Splash player).
GUI:
1) ADD an option to Associate file types to Splash thorough the GUI settings.
AUDIO:
1) When using an MP3 with Splash the big screen with the logo is loaded, you shuld make it that when using splash to play music files it will load a small playing bar without the logo.
2) ADD playlist support for music.
thank you.
lbamda
Sat Feb 26, 2011 8:21 pm
Whether as constantly it is necessary to switch off/on Motion2 (in Playback options) it is possible to add keyboard shortcuts for on/off this option?
mamilko01
PC Specification: AMD PII 720BE W7
Sun Feb 27, 2011 7:41 am
What would be great, is to make a navigation menu option like it is in the Zoom Player for normal browsing with the remote control. Than it would be the best player in the market.
aminnazifi
Sun Feb 27, 2011 9:09 pm
tuvi123 wrote:Great update but you did not add the must-have improvements.
some suggestions:
SUBTITLES:
1) BOLD subtitles.
VIDEO:
GUI:
AUDIO:
thank you.
yeah i`m agree
Ralf
PC Specification: Intel E6850, Nvidia GTX 260, Win7 64 Bit
Mon Feb 28, 2011 8:07 pm
GUI:
Yes, thats very important for me, too. Because Media Player is stealing some times file association.
Ralf
Mon Feb 28, 2011 8:16 pm
And I have a problem which persists still in all Splash Pro versions...
The pause/resume key on my Logitech DiNovo Mini don't work with Splash Pro. In Media Player and WinDVD it works perfectly.
Can you please have a look on it? :?:
Anonymoose
PC Specification: GTX260 / Q6600 / W7 SP1
Tue Mar 01, 2011 4:25 pm
browser plugin for flash/anything video...
I can always dream :twisted:
