icsterm
Contact: Yahoo Messenger
Re: Splash PRO 1.6.0
Sun Mar 13, 2011 2:39 pm
Nielo TM wrote:
Florin64x wrote:Can * Motion² Ultra 1080p option added for the ultimate video quality. This feature is designed for processors with 4 (or more) cores. (available in Settings/Video) be enabled on 3 cores processors too , cause i have 3 cores processor phenom II and i cant enable this feature.
It can't be enabled on Tri-Core systems
There are some Qxxx CPU's that have 4 core 4 threads and more i5 CPU's with 2 cores and 4 threads. Some faster dual core's exceed older native quads. Please enable this feature for all users. And add some minimum CPU requirements for 'Ultimate 1080'. Like i said, older quads are slower than newer dual core's.
As far as i'm concerned, AMD sucks at performance per core but a tri-core should work with some OC.
EG: My i5 430M CPU can take OC up to 3.1 GHz on both cores and sintethic benchmarks shows it's too close to 720QM or better.
Btw, how much load will the new option take on the i7 quad? I'm sure desktop versions have no issue, i'm talking about notebook cpu's.
Nielo TM
Sun Mar 13, 2011 2:51 pm
icsterm wrote:Why isn't motion 1080p enabled for Core i5 mobile CPU's that have 4 HT cores? I think a 3 GHz clocked i5 should be fast enough. The tick option should be freely available for users to experiment.
Some dual core CPU's can keep frequencies higher than any Quad. Will it lag so bad?
Also, why skip versions so fast? There are features like in-menu file associations and some more 'critical' stuff missing,.
Hyper Threading is different to actual 4 physical cores and higher clock frequency doesn't mean better performance (at least in the case of MCFI).
They must have chose 4 core for a reason. Maybe each core is interpolating the intermediate frames simultaneously to create one clean intermediate frame (similar to HDR photography).
Florin64x
Sun Mar 13, 2011 5:46 pm
I have Phenom II x3 720 Black Edition overclocked at 3.2 ghz per core.
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Sun Mar 13, 2011 7:32 pm
- deleted -
lbamda
Sun Mar 13, 2011 8:24 pm
On this version, on the former (as well as on the version 1.5.0), has not work hardware deinterlacing (ATI 5770 Win7 10.12 drivers H.264/AVC 1080i/60i source in mkv) - On the version Splash PRO 1.4.0 all was excellent.
Kagachaz
PC Specification: Vaio, Nvidia GeForce 310M, Windows7 64b
Mon Mar 14, 2011 12:22 am
icsterm wrote: The tick option should be freely available for users to experiment.
I couldn't agree more, my laptop has an i7 720Q processor yet I still cant use the motion 1080p, I even tried looking to see if the Affinity was set to 4 cores on the program and sure it enough it is. I have turbo boost up to 2.8Ghz and a Nvidia Geforce 310M graphics card though, so maybe its not about how many cores you have if I cant have the option available.
Either way Im suprised I didnt have the option available..
resinate
PC Specification: Win7 Ult
Mon Mar 14, 2011 5:37 am
the motion plus doesnt seem to work as good as 1.5.0
icsterm
Mon Mar 14, 2011 10:21 am
It might be some CPU detection mechanism that activates the option if the CPU has some minimum TDP value or minimum frequency. Or it might support only the faster i7 CPU's.
Still, so few information in the included PDF manual. It's a shame.
metal005
Mon Mar 14, 2011 10:48 am
anybody compare v1.6 on AMD 4-core and 6-core? will 6-core show any improvement over 4-core (same clock)?
marauderxp
PC Specification: I7 870 @ 3.9ghz, GFX 580, Windows 7 x64
Thu Mar 17, 2011 3:57 am
I found this thread some time ago relating to something called 'core parking' in Win7. http://forum.cakewalk.com/tm.aspx?m=186 ... print=true. It seems to have an ill effect on occasions with some software, so it might enhance performance who knows.
