belboz
PC Specification: Intel i7-3630GM, Nvidia GTX 680M, Win 8
Re: Users' Wishlist
Wed Nov 18, 2015 7:15 pm
Not sure if my suggestions are new, but will list them here. Had Action for a couple years now, but really wish they would add the following.
1) A third audio track for recording. So I can do Game/Microphone/Teamspeak all in sep tracks.
2) Push to talk release delay. Can't believe this isn't in there. Would like a slider to be able to adjust that. I usually use about 250ms on other comm apps.
3) The ability to blacklist certain apps from the FPS hud. I hate seeing it in VLC or other apps I don't want to record in.
Montago
Re: Users' Wishlist
Wed Feb 03, 2016 2:32 pm
belboz wrote: 3) The ability to blacklist certain apps from the FPS hud. I hate seeing it in VLC or other apps I don't want to record in.
make a txt file called exclude that sits next to Action.exe
then insert per line, the name of EXE files that you want to exclude.
eg:
rdp.exe
photoshop.exe
explorer.exe
JoseM
PC Specification: Beelink SER6 Ryzen 5 6600H 16GB DDR5
Re: Users' Wishlist
Fri Feb 05, 2016 9:39 pm
-Having control of additional gain for the microphone
-More configuration options for recording with Nvidia
Montago wrote:make a txt file called exclude that sits next to Action.exe
eg:
rdp.exe
photoshop.exe
explorer.exe
Thanks for the information
Jaffo
PC Specification: i5-4460, GTX 960, Win7/Win10 64 bit
Re: Users' Wishlist
Wed Mar 02, 2016 2:56 pm
I apologise in advance if there are options/workarounds for the following:
-Separate hotkeys for recording and streaming. I've lost count of the number of times I think I'm recording to disk only to discover I'm streaming or vice versa!
-Ability to change recording settings in-game eg. time-shift length, frame rate etc.
-Ability to move the region capture icon bar; it often obscures the controls of whatever you are recording.
Very happy with Action! on the whole, just a few niggles like these that I'd loved to see ironed out.
Dobs
Re: Users' Wishlist
Fri Apr 08, 2016 4:50 pm
Able to program Joystick button as microphone record key.
Currently have to assign a key for microphone. Assign a button to mimic that keypress in an additional software program. Make sure your Voice app (teamspeak, vent, etc..) has the right button selected for press to talk. And then you can record your microphone in game.
Hate the always record option....get keyboard, background noise, dogs, wife, kids etc...
Just make it recognize the devices that windows already recognizes....
Danish Warrior Skald
PC Specification: Windows 10 64 bit
Re: Users' Wishlist
Sun May 01, 2016 12:25 pm
Hi, great recording software! I use it for my You Tube channel almost daily!
My wish: That the FPS counter automatically disappears, when taking a screenshot in Steam with Steam F12.
There is a hotkey for this F6, by standard, I know and use it!
But in for example a Total War: Shogun II recording, where I want to take a screenshot, I have to first press the F6 to remove the FPS counter from Mirillis Action and then K to remove the UI/HUD In-game and then take the screenshot with Steam F12! In Fraps, the FPS counter would automatically hide when pressing Steam F12.
Best regards,
DWS
TeslaStormX
Re: Users' Wishlist
Mon May 09, 2016 12:40 am
For whatever reason, using push to talk (Not the on/off button mode) cuts out way too quick. It would be nice if there was a delay option for the microphone like in teamspeak3. Like delay releasing push-to-talk? Example 1 second of recording the microphone? Another issue with action is whenever I change the fps of the video and reset action it reverts it back to the default option it had before. (30 fps to 60 fps) The only reason why I do this is because 60 fps video doesn't work on movie studio but 30 fps. My last request is to have a better live steaming options such as obs. OBS destroys Action on steaming options because it has more options and settings than Action.
What I want to see in Action!
Delay releasing Push-to-Talk, Profiles of settings, More Live streaming options
Thanks for reading this is my first post in the forums! :D
Death
PC Specification: Windows 7
Re: Users' Wishlist
Fri May 13, 2016 1:23 pm
Action! is great. It really is. But there is one flaw: Rendering queue. I know, we ask for this a lot.
But I'd also appreciate a simple "workaround": command line arguments
like Action.exe --render Video.avi
which would automatically render Video.avi and then exit Action!
This way we could automate rendering (e.g. with Python) ourselves (which would be very helpful, as there are tools out there to automate everything from rendering, uploading, setting title/description/tags and generating a thumbnail. With command line arguments, the rendering process could be integrated into those applications).
Anyway, thanks for this awesome application!
OCed
PC Specification: 4790k, 980ti AMP Extreme, Win10 Pro 64
Re: Users' Wishlist
Sun Jun 05, 2016 9:50 am
Microphone ON/OFF Icon next to the Action! Ingame HUD. So i can see if my mic is on or off.
Red Icon = Mic OFF
Green Icon = Mic ON
PLS it would be really nice.
i7 4790k 4.4Ghz, 980ti AMP Extreme, 16GB TridentX 2400Mhz CL10, 1x Kingston HyperX Black 240GB, 1x Klevv Urban 480GB, 1x WD Purple 1TB, Eizo FS2735, Creative X7, AKG K701, Auna Mic 900B
marciomachida
Re: Users' Wishlist
Thu Jun 23, 2016 4:12 pm
- Add CUSTOM framerate, instead 30-40-50-60-120.
Thanks.
Users browsing this forum: No registered users and 46 guests
