Tonycubed2
PC Specification: 1080ti video, 7880 cpu, win 10 pro
Thu Sep 27, 2018 4:46 am
I have 3,40 , Action! crashes after recording is stopped. Every time. then it will try to start and keep crashing then try to start over and over until I delete or move the video it makes.
Thu Sep 27, 2018 6:23 am
Does the issue occur both for AVI and MP4 recordings? Please provide us screenshots from following tabs: Video Recording, Video Settings, Audio Settings.
weilar
PC Specification: I5 - 3.2 / 32 Gb / GTX 1050 TI / 2 TB HD
Sat Sep 29, 2018 3:04 pm
Hi all, I've got same problem that many of you, with V3.4, I made some tests, with Action, and see that the problem comes when i try to record videos with more than 30 min, 5 - 10 - 20 record ok (it took a long time), with all sounds active. The problem as i see was in this long videos, so i test different things, and It seems the problem comes from "Export" option, if i try to change the directory to export, the Action program crash, so I remove all options in export and the "Hardware acceleration" option in every slide. And works fine for me.
I think that problem comes, because action is not compatible with the hardware acceleration option of the GTX Graphics Cards, as my problem comes when i put a GTX 1050 TI in my computer, with the GT 730 i record videos with 3.4 without any problem.
Hope this will help. :mrgreen:
Cheers.
-MD-
PC Specification: Windows 8.1
Mon Oct 01, 2018 5:47 pm
I've had this same exact issue for well over a year and half.
Doesn't matter what version of Action I use. The only fix for me was going back to a Nvidia graphics card from December of 2016. Once in a while I will accept a Nvidia graphics card update to see if it will work, and nope, crashes when stopping the recording.
When this issue started for me way back. I sent multiple emails to support and they seemed to have given up and had no answers then.
Can someone from support please answer why this might be, and a possible fix?
Tue Oct 02, 2018 6:06 am
Cheers.
Try adding video output folder to exclusions in your antivirus software.
drtechnoid
PC Specification: 390x
Sun Oct 07, 2018 11:15 pm
Hello
I wanna use the app for record ww2 cod gameplays. when I start the app , cod will crash. Every time I do this , no exception.
So what is wrong with this whole thing ? I was using this to record gameplays in the past years , and it is not working in 2018 anymore. This is not the reason I bought your product.
rexzone
PC Specification: fx8320,r930x,win7
Thu Nov 01, 2018 2:53 pm
I also have the same error, and made an exception run in the antivirus, updated to the latest drivers and nothing.
it's annoying that a video that would have taken me 15 minutes took me almost an hour to fix something, pay for this product and request some solution
Tue Nov 06, 2018 6:40 am
Do you record in external or internal drive? What antivirus do you use?
Wiesobinichda
PC Specification: Amd Radeon Graphics, Windows 10, I7
Recording crashes after stop
Sun Nov 11, 2018 12:31 pm
Hello my action latest version always crashes when I make a recording and then stop when I restart action is the recording as "file can not be opened" Thank you LG Wiesobinichda Ps: My bad English is because I am from Germany
weilar
Sun Dec 16, 2018 12:02 pm
Cheers.
I tryed to set exception in my Antivirus, as Action is again crashing, and no way. I'm using an external HDD and AVG antivirus.
Users browsing this forum: davidroman and 8 guests
