nagoli
PC Specification: Phenom2 965, 4Gb DDR2, HD5830, Win7 x64
Re: Splash PRO 1.2.1, 1.2.2, 1.2.3 & 1.2.4
Wed Oct 20, 2010 9:42 am
It's 10m
However I can play the sound ok with MPCHC+DXVA+Matroska+FFaudio so I don't think the issue is with my HDMI cable.
Anyway the same happens if I only send the audio that way but keep the picture on the monitor.
Unfortunately I can't get rid of the frame drops in MPC which makes a choppy playback this is why I was blown away by the smoothness with Spalsh.
So now I just have make the HD audio passthough working with Splash and I'm a happy camper.
NumB
Thu Oct 21, 2010 3:58 pm
error with version 1.2.4:
Code: Select all
CODEC ERROR:
Please install DivX Codec.
i have to specify that i already have installed the codecs pack that comes with BSplayer... sorry for the advertising...
Joco1114
Fri Oct 22, 2010 2:57 pm
My opinion: install FFDShow from this link:
http://sourceforge.net/projects/ffdshow-tryout/files/
Home Theater:
Synology NAS 1010+ | 9TB HDD
icsterm
Contact: Yahoo Messenger
Sun Oct 24, 2010 10:39 pm
Joco1114 wrote:My opinion: install FFDShow from this link:
I think windows seven has its own divx codecs bundled in. I'm not sure about windows xp. But shouldn't Splash contain the DivX codec already?
aviwil
Mon Oct 25, 2010 12:16 pm
For those with sound problems , turning off Audio Boost , may help .
BDX
Mon Oct 25, 2010 6:43 pm
Yes, but pretty bad one. No, XP doesn't have one. Yes, ffdshow atleast.
tony_montana
PC Specification: i7 860@2.80 GHz,HD Radeon 5850,Win 7 x64
Mon Nov 01, 2010 5:47 am
who said windows 7 divx ccodec are not good?
