Tue Dec 18, 2018 7:23 am
Try recording on internal HDD/SSD.
weilar
PC Specification: I5 - 3.2 / 32 Gb / GTX 1050 TI / 2 TB HD
Wed Dec 19, 2018 10:46 am
Same result, Action crashes.
Is there any way to recover an old version of Action?, Version 3.4 was working really fine.
Thx.
Nonny
PC Specification: Intel i7 5960x, Nvidia Strix GTX1060
Thu Dec 20, 2018 4:20 pm
I didnt read all the entrys here but maybe it helps , i had also when closing a recording crashes , usally when i took a record in game with 720p more then 30 til 40 minutes , it was not possible to record longer then that , a real pain in the neck , for me the solution was :
Add to Avast! Virus scanner an exeption in "File/Archiv" protection AND also in "Behavor or Heuteretic Protection" , because Avast! is scanning EVERY "newly generated Files" SO sometimes it takes so long that Action! was crashing because of that ! ... the exeption lines made it work no matter how many time i am recording now , like 1h and 40 minutes game play NO PROBLEM anymore! So is there Avast! in use THIS can be the problem of the crashes when no exeption line a inserted , in the list has to be excluden the Action! folder and then it should work , for me it was :)
SORRY for my english and i hope maybe it helps !
Nonny
Tsura
PC Specification: gtx 1060 6gb, i5-4670k@4,0 ghz, win 10
Wed May 29, 2019 7:07 am
Hi.
From paste few months I have this problem with my Action! After every recording it crashes and restarts. Sometime it happens also few seconds after starting a record.
My settings doesn't matter. It crashes when i use avi, mp4, different folders on different drives (ssd, hdd). It happens when i record one soundtrack or 3 of them. Also doesn't matter if i have any antivirus tool running in background.
Do you have any solutions for this problem?
thebigbishop
PC Specification: Windows 10, i7-6700, HP Bang & Olufsen
Action crashing after recording.
Thu Jul 11, 2019 5:13 am
About two years ago I purchased this software, and had been using it to record 30+ minute videos for about a year following; as of the past 6 months this software has refused to work for me. Pretty much everything works well for me up until the recording reaches up to 5 seconds. The problem happens when I end the recording, and the entire software crashes and takes a whole 2 minutes to end the task.
Windows 10
Intel(R) HD Graphics 530, Intel(R) Core(TM) i7-6700
HP ENVY 750-137c
Watchman
Re: Action crashing after recording.
Thu Aug 08, 2019 8:24 am
Windows 10
HP ENVY 750-137c
Can you please let us know it this only happens with MP4 videos or AVI as well?
Myrakiel
PC Specification: Intel I7, Geforce 1070 GTX Ti SLI, W10
Wed Oct 16, 2019 1:42 pm
Your Action video recording settings:
Capture: Screen
Format: MP4
Acceleration: Nvidia Nvenc
Dimensions: 1080p
Images: 60FPS cfr
Screen: Desktop 2
First source: default
Volume: 100%
Secondary sound source: no
Webcam: no
Your Action audio settings:
Perip: default
Format: Mp4 audio
Microphone: always recording
Silence: record
Does Action! crash only in MP4 format but not in AVI?
It crashes for both
Do you use any external USB audio devices?
Yes
DxDiag report of your PC
DxDiag.zip
(15.64 KiB) Downloaded 14439 times
Thank for your help.
Thu Oct 17, 2019 5:55 am
Capture: Screen
Format: MP4
Dimensions: 1080p
Images: 60FPS cfr
Screen: Desktop 2
Volume: 100%
Webcam: no
Perip: default
Format: Mp4 audio
Silence: record
It crashes for both
Yes
DxDiag.zip
Try two things:
- go to settings -> audio and disable "record sound" option
- disable antivirus software
tschmelcher
PC Specification: Windows 10, AMD 3800X, NVIDIA 2080 Ti x2
Sun Mar 15, 2020 7:55 pm
This issue is fixed for me in 4.2.0.
WhitePalmer
PC Specification: Core i7-8700, GTX 1070 TI, WIndows 10
Fri Apr 03, 2020 7:55 pm
Hi all.
I have following issue.
In recoring in mp4 action! freezes after stop record.
In recording in avi everything is ok, but audio track is empty (have no sound)
Action! 4.4.0
Windows 10 x64
Capture: Screen, Game, Area
Format: MP4
Dimensions: Original
Images: 60FPS vfr
Video quality: high
Bitrate 100%
Use multicore recording
Record mouse cursor
Primary Sound Deivice (system sounds) - ZOOM UAC-2 Speaker (ZOOM UAC-2 Audio)
Volume 100%
Secondary Sound Device (Microphone) - ZOOM MIC (ZOOM UAC-2 Audio)
Volume 100%
Enable additional audio recording into separate audio file - ZOOM MIC (ZOOM UAC-2 Audio)
DxDiag.rar
(13.98 KiB) Downloaded 13863 times
Yes, more precisely freezes
Yes. I use Zoom UAC-2
