Welchy10
PC Specification: i9-9900k, RTX 2070 Super, Windows 10 Pro
Thu May 07, 2020 1:49 pm
This has just started happening for me now as well after updating to release 4.6.0. Only fails on MP4 recording. AVI is fine.
Have completely uninstalled Action and reinstalled no success. GFX drivers are up to date.
Windows 10 pro
RTX 2070 Super
i9-9900k
Settings
MP4
NVIDIA NVENC
1080p
60 FPS VFR
Active Screen = Desktop 1 (tried with 1 and 2, doesnt work)
Copying info from another post:
Does Action! crash only in MP4 format but not in AVI?
Yes, AVI records and exports fine
Do you use any external USB audio devices?
Normally I record to a USB3.0 Ex HDD. But on this occasion I am trying to record directly to internal SSD drive. I have an external USB 3.0 hub plugged in, with microphone, elgato capture card plugged into it.
dx diag report
DxDiag.rar
Please assist.
Fri May 08, 2020 6:16 am
Windows 10 pro
RTX 2070 Super
i9-9900k
Settings
MP4
NVIDIA NVENC
1080p
60 FPS VFR
dx diag report
DxDiag.rar
Please assist.
Install version 4.5.0 and see if it works: http://downloads.mirillis.com/files/act ... _setup.exe
Luk
PC Specification: Amd 6300 a4 ,Ram 8Gb, w10 x64, gt710 2G
Wed Oct 28, 2020 12:25 pm
Same for me , crash in last version 4.12.2 and 4.5.0 with sound activated , if I deactivate it, if it records normally in mp4
Weezo
PC Specification: Cpu 15 8300h, nvidia 1050, win 10
Mon Nov 16, 2020 8:44 pm
I had this problem. Then i went to SECONDARY SOUND DEVICE (Microphone) and make sure I select "Realtek Hi Def Audio". In other words I had to make sure that my secondary audio was set to the system audio card as opposed to any other audio I had connected to my system (like bluetooth stuff). Once I did that, the crashing stopped.
gabinetzabiegowy
PC Specification: G11 win11
Contact: Website Facebook
Sun Feb 11, 2024 4:54 pm
I have such problems after the update...
IndigoAK
PC Specification: Windows 10 64-bit, Intel CPU, NVIDIA GPU
Mon Sep 08, 2025 7:05 pm
I am now experiencing this issue with 4.45.
I have tried so many things to try and get it to work. I've tried reinstalling Action, I've tried rolling back my drivers (with a clean rollback using DDU), I've tried closing all extra apps, I've tried a different codec. It was working just fine on Friday, but when Saturday came around it suddenly stopped working. The overlay hangs on the green downloading arrow and I can't even bring the main application up from the system tray and have to force close it, which doesn't provide a report for Windows. I tried leaving the window open so that it would hang with the dialogue, which does generation a report, but it just says the faulting applications are things that we all working fine before and have not changed. No surprise updates, no surprise settings changes, nothing.
This is extremely frustrating because there's no other app that does what Action does as well as it does. Steam's new built-in recording sucks.
Mysterium
PC Specification: AMD 9950X3D Nvidia 4090 Win 2025H2
Sun Nov 09, 2025 9:13 am
Same here! It crashes since a few weeks ago. It might not work since a Windows 11 Update or Unreal Engine? Because on my Laptop it din´t work either! Tested on 2 different Systems. Some older Games can be recorded, newer Games not. Unity Games works mostly. Unreal 5 not, Cyberpunk 2077 not anymore.
Nvidia Recoder or other like Medal, Momentum are functioning, but i want the recordings with 5.1 sound recorded, so i want Action! working again!
Tried various things, nothing worked. Like i said, on my laptop, it worked not too.
emy
PC Specification: Ryzen 7 7800x3D, ROG 4090, Windows 10
Tue Nov 11, 2025 6:37 am
I am also experiencing this on 4.45...
My action crashes sometimes at the start when trying to record, but my main issue is when trying to record in the game mode preset. It will record sometimes, and if it does manage to, as soon as you end the recording, the HUD hangs with a green arrow appearing, and doesn't save the recording. Action then freezes/crashes. The only way to close is with task manager.
I have tried with the other presets like screen and area, and no problems as normal lol no freezes or crashes, but the motion looks terrible just doesnt look right compared to game preset...
When using obs no problems with recordings, but I don't want to use obs. i prefer action.
This sucks, especially getting no reply from the support tickets I have sent.
Users browsing this forum: No registered users and 44 guests
