bennsoncat
PC Specification: i7-7700, R9 285, Win 10
Re: Users' Wishlist
Mon Apr 03, 2017 11:10 am
DamianToczek wrote:
bennsoncat wrote:Please add Intel Quick Sync H265 support.
It's added, if you dont use Nvidia Acceleration you use as default "H265".
No, if I use Intel Quick Sync, it always uses H.264/AVC.
And I have an AMD card, so Nvidia Acceleration should have nothing to do with it.
Malcomwilk
PC Specification: win 10, geoforce 750 ti, 16gb ram.
Re: Users' Wishlist
Sun Apr 09, 2017 4:48 pm
Please add the ability to choose whether I want CBR, CFR, and VFR.
DyzGames
PC Specification: fx-6300, Nvidia GTX 960, windows 7
Re: Users' Wishlist
Fri Apr 14, 2017 6:23 pm
Please, I really want to have the option to set the microphone in mono (my stereo mic is broken and only records one side)
_phantom_
PC Specification: i7 Lynnfield, EVGA GTX 570, Win 10 Pro
Re: Users' Wishlist
Tue Apr 25, 2017 1:31 am
it is possible in later versions can be added that each audio track is independent,
example .. track 1 audio game, track 2 skype, track 3 microphone 1, track 4 microphone 2 ..? Have multiple inputs for different audio tracks?
DrunkMonk74
Re: Users' Wishlist
Mon May 01, 2017 2:07 pm
Cannot tell you how long this has been asked for without any meaningful response coming back!!!
techdude66
PC Specification: 2.50GHz i7-4710HQ, Win10, 8GB RAM, 970M
Re: Users' Wishlist
Wed May 17, 2017 7:33 am
The ability to screenshot in USB/HDMI Mode?
The hotkey's grey in the settings. :?
Montago
Re: Users' Wishlist
Sun May 21, 2017 7:41 am
Option to disable Splash Screen ...
its sooooo freaking annoying !
Badfist
PC Specification: CPU I5-4670 |Radeon R7 |Windows 10
Re: Users' Wishlist
Wed May 31, 2017 8:02 am
the compatibility to run reshader on games. on some games we need to put d3d9.dll on bin folders and this is make action to dont work.
Eden Genesis
PC Specification: NVIDIA
Re: Users' Wishlist
Fri Jun 02, 2017 12:17 am
I had a lot of suggestion, but one of my whish is that we can place our logo manually on the screen just like we place an icon on photoshop.
It would be nice to set an option to make it appear or disappears whenever we want or at least but a timer on it because on some videos, the logo ruin the visibility. I just want to use it as a watermark for my video, but it doesn't need to be visible for the full video. I know it's possible to do it on 3rd party softwares, but I'd prefer doing evrything right from Actions!
More suggestions to come...
Sone
PC Specification: Win7Pro64, GTX970
Re: Users' Wishlist
Thu Jun 22, 2017 12:50 pm
1. Ability to set additional microphone recording key.
Thanks.
