Re: Action! 1.9.0
Thu Aug 23, 2012 2:15 pm
QuUuQ wrote:Hello,
when i record a game,Action! lock the framerate.
It doesn't. There's no such function in Action! that could lock the in-game framerate.
Kashimus
PC Specification: windows 7 ultimate x64
Re: Action! 1.9.0
Thu Aug 23, 2012 9:29 pm
QuUuQ wrote:Hello,
Its show the recording frame rate not the actual game frame rate, its a bit confusing,and misleading...
delod
PC Specification: Ati 5600hd - intel i 7 - windows 7 sp1
Re: Action! 1.9.0
Fri Aug 24, 2012 10:29 pm
hello my native language is not English sorry if I make a mistake
I love action but in this latest version I have a very rare mistake
when I start the program remains frozen, I can change the configuration options or write or do anything, I do not see the version of the program
entoces try to close it by force alt - control - delete
and in the process list and kill Action_x86 Action_x32
until there is no process of Action
I open entoces action and it works! loads and closes properly and I can use it without bug
but on every reboot and do the process of killing
Re: Action! 1.9.0
Fri Aug 31, 2012 11:01 pm
New Action! 1.9.2 is now available for download:
Change list:
* Fixed recording of games with FXAA mode installed. In example: Alan Wake, Battlefield 3, Skyrim
* Fixed desktop region recording with region width set to 1280 and with video size set 720p (shifted video problem)
* Fixed Flash player stability problem (Firefox browser) with Action! running
* Fixed problem with Skype stability with Action! running
* User Manuals updated
* Small GUI improvements
* Multi-language installer added
This version introduces new installer - it is recommended to uninstall previous versions before installing Action! 1.9.2
Miguel
Re: Action! 1.9.0
Sat Sep 01, 2012 12:56 am
Ghost wrote:* Fixed recording of games with FXAA mode installed. In example: Alan Wake, Battlefield 3, Skyrim
It works, but if Fraps is launched at the same time, there's some randomness that make the game to crash, or not load the FXAA/SMAA mod, or load the mod but after Action!, and then the FXAA/SMAA effect is not captured in videos.
But without Fraps, it's loaded in the right order and the FXAA/SMAA effect is visible in captured videos.
Ghost wrote:* Fixed problem with Skype stability with Action! running
I can confirm it, thanks :)
Kashimus
Re: Action! 1.9.0 & 1.9.1 & 1.9.2
Tue Sep 04, 2012 11:24 am
When will the overlay show the actual fps during recording, not the preset recording frame rate (30,60,25,)giving the illusion of locking the frame rate during recording ,and the recording time?
Gallow24
PC Specification: Intel Q9550, 8GB DDR2 800, Radeon 5870
Thu Sep 06, 2012 4:44 pm
Some weeks ago i postet a problem, but it is not fixed until now. I´ve sent it to the support, too.
Action! does not work with games using a d3d9.dll. This file is sometimes a graphic-tweak or an overlay. I have problems with games from simbin, battlefield3 and world of tanks.
Regards
Steffen
Thu Sep 06, 2012 9:35 pm
Gallow24 wrote:Some weeks ago i postet a problem, but it is not fixed until now. I´ve sent it to the support, too.
Regards
Steffen
Graphics mod issues such as FXAA Injector has been fixed and we received feedback that it's working.
Fala7er
PC Specification: i5 2500k, GTX680, Win7 x64, 16GB Ram
Fri Sep 07, 2012 12:19 am
Can you add a small but very helpfull option:
On the recorded videos that we can play inside action it would be nice to have an option to rename the files :D i use madvr to render on my player and if i play the .avi file i can't see the video and i need to switch to the directshow render to see which video file is or open action and check the filename too. Renaming the files will make this process of identify the files a lot easier.
Thanks for reading and keep the great job with action! :mrgreen:
Fri Sep 07, 2012 12:55 pm
Fala7er wrote:Can you add a small but very helpfull option:
You can change the name by clicking once on the file name in Action! browser. Here's a screenshot: http://i47.tinypic.com/2e1rmmt.png
