Re: ACTION! 1.12.0 & 1.12.1
Tue Dec 18, 2012 7:05 pm
jimquim wrote:so did you check it i need to not convert to then i will just use another software thanks
YouTube allows only mp4 files to upload. AVI are not supported so you have to use our built-in exporter or use another software to do this.
Dahnark
PC Specification: I7 3770k GTX 670 Windows 7 64Bits
Wed Dec 19, 2012 10:58 am
is possible that in future versions, add the option save the microphone audio in other file, and not only in the .avi?
use virtualdub for videos with 30 min of audio and then import to premiere or vegas the video with the 2 audio separated in files with virtual dub is a lot of time lost...
minomk
PC Specification: i5 750, 8GB DDR3, GTS 250, Win8 64bit
Sun Dec 23, 2012 2:01 pm
any new release news? :)
Sun Dec 23, 2012 9:41 pm
Sony Vegas is supporting video files with two audio paths. So there's no need to export it in VD.
Re: ACTION! 1.12.0 & 1.12.1 & 1.12.2
Fri Dec 28, 2012 1:43 pm
New small update is now available (1.12.2 version) with fixed activation window for high DPI settings in Windows 8.
GamerGuy
Sat Dec 29, 2012 4:29 am
I can't seem to get 1.12.2 to work. When I click the stop button to stop recording it just hangs and never finishes writing the video to disk.
Please provide a link to the prev version 1.12.1, thanks.
edit: never mind, appears to be solved after I changed (again) my laptop to run action.exe on the intel gfx instead of amd gfx. I guess I have to reset this power preference each time action.exe gets updated.
keeper
PC Specification: q6600, gts 450, win 8
Sat Dec 29, 2012 8:53 am
Suggestion: Nice to see an option "Loop Buffer Record" like in Fraps. And d3d8 support recording.
MrT
PC Specification: i7 920, Palit GTX275, Windows 7 x64
Wed Jan 02, 2013 3:30 pm
Guys, Action! rulez, but I really would be glad to see 2-pass encoding presets.
Buffometer
Contact: ICQ
Sat Feb 02, 2013 11:38 pm
It would be nice if you add an automatic limiter(which can be turned on(when the audio signal is greater than 0db) or off) for overloaded sound from microphone, in order to avoid audio clipping, of course in future versions.
Thanks.
SysL
PC Specification: i7-960>EAH6950/2DI2S/2GD5>Win7-x64
Sun Feb 03, 2013 1:21 am
turn off the computer file export process?I hope that is such a feature in the new version.
