HippoZoned
PC Specification: FX-6300, 8g ram, AMD2gb 7770 ghz edition
Re: Action! - performance test results
Wed Sep 03, 2014 1:30 pm
Those of you asking for a test vs DXtory here is my verdict
http://forum.mirillis.com/viewtopic.php?p=47679#p47679
the9quad
PC Specification: i7 4930k, 3 X 290x's, Windows 10 64 Bit
Mon Dec 22, 2014 6:57 pm
Dxtory direct output to just about any streaming program (FFsplit,Xsplit broacaster, or OBS) is actually better quality and less of a performance hit than Action! The latest release of Action! broke AMD APP with crossfire which led me to start testing other apps. The results surprised me, not sure if I am going to go back to Action! now even if they fix it. Maybe if Action! starts adding some other streaming functionality like chroma keying, camera support, more overlays etc.. it will justify the monthly price to stream, but as of right now the value isn't there when other programs have way more features.
here is a run down of every popular streaming option, all streams were done at 720p/30 fps from 1440p ultra BF4 gameplay footage on test island. NOTE-You can look in the right hand corner to see the framerate. in addition, where it was possible to adjust, the bitrate was set for 3000
X-Split with Gamecaster is complete and utter garbage,
http://www.twitch.tv/the9quad/c/5726257
X-Split with Broadcaster is really, really great but crossfire will not work.
http://www.twitch.tv/the9quad/c/5726252
Raptr is ok, but once again crossfire is broken
http://www.twitch.tv/the9quad/c/5726262
Raptr with MANTLE and Crossfire is well yeah it's broke really bad
http://www.twitch.tv/the9quad/c/5664877
OBS the VCE build will not work with crossfire in BF4. Other than that it is really good.
http://www.twitch.tv/the9quad/c/5726278
Playclaw with AMD VCE will work in crossfire but it gives a performance hit.
http://www.twitch.tv/the9quad/c/5722145
Action! VERSION 1.20.2 is great to use but crossfire has been broken in this latest version
http://www.twitch.tv/the9quad/c/5726063
Action! version 1.17.3.0 works phenomenal with almost zero performance hit and CROSSFIRE WORKS!
http://www.twitch.tv/the9quad/c/5726050
DXtory direct show output to X-Split Broadcaster- It works very awesome indeed. Crossfire works, performance hit is next to nothing and quality is good.
http://www.twitch.tv/the9quad/c/5728500
OBS+DXtory very awesome results as well, crossfire works.
http://www.twitch.tv/the9quad/c/5728630
FFSplit + Dxtory same as the last two really good and crossfire works
http://www.twitch.tv/the9quad/c/5728933
So really the only three choices that work with crossfire are:
1.) Action 1.17.3.0 using AMD APP
2.) Dxtory with direct show output to some other program (OBS,FFsplit, or X-Split broadcaster)
3.) Playclaw version 5 using AMD VCE, but it has the worst performance of the three.
maitrishah1
PC Specification: Windows
Fri May 11, 2018 9:29 am
Action! records videos in its own format called FIC. This is highly optimized codec for games and desktop recordings.
lukenlow
PC Specification: Windows 7
Wed Aug 01, 2018 11:28 am
This is extremely useful to know, thanks for giving time to their studies and sharing the results.
