P.J
Re: Best settings & decoder
Sat Oct 01, 2011 10:06 pm
Software Decoding:
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 40.5 MiB
Duration : 21s 112ms
Overall bit rate : 16.1 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=12
Codec ID : 27
Duration : 21s 40ms
Bit rate mode : Variable
Bit rate : 15.1 Mbps
Maximum bit rate : 16.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.291
Stream size : 37.8 MiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 21s 152ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 992 KiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 20s 576ms
madVR:
Splash:
ocd
Sun Oct 02, 2011 3:31 pm
Knight: I have given up on Nvidia Settings. The control panel is horrible and doesn't allow for custom profile, i.e. changing Brightness/Contrast and other settings specifically for a video player. I just use Splash settings to get the correct Black levels with my calibrated display. The only major issue I have is not with Splash but with Nvidia not fixing their color banding/gradient issue when playing back HD codecs. I have gone over to the dedicated solution and Remux any file I have to work with my TV built in player. It's very basic but atleast the picture quality isn't so bad as Nvidia. I use Splash whenever I need to view anything on the PC. I am hoping for Splash to address this somehow without costing too much CPU usage but I am afraid it will need to be done in software mode as Nvidia is too busy coming out with new cards and not addressing issues with what already exist. Very sad. :(
vivan
Mon Oct 03, 2011 2:51 pm
P.J,
Oh, interlaced stuff.
If you use software decoding - than install ffdshow.
Use such settings:
And don't forget to disable video decoder in madVR (processing -> decoding).
PS Vita, Nokia N8
P.J
Mon Oct 03, 2011 9:09 pm
Nvidia has one of the worst support.
Playback speed: 3fps compared to 60fps in Splash :idea:
Not much difference except color (happens in Splash's CPU mode) and sharpness (0 in my test).
alizee
PC Specification: AMD phenom X4 970, HD5770, windows 7 32
Wed May 09, 2012 5:25 pm
is there any difference in smooth video playback support in splash, using GPU enabled or not?
I mean, with gpu not enabled, motion2 ultra 108p enabled will be used in 720p mkv playback giving smooth playback, or the gpu needs to be enabled for motion 2 ultra 1080p to work...
I`m not talking about motion2 in "during playback" options...
P.J
Thu May 10, 2012 6:11 am
alizee wrote:is there any difference in smooth video playback support in splash, using GPU enabled or not?
Already answered in your topic.
