locutus
PC Specification: Intel i5, GeForce GTX590, Win7 Pro 64bit
Re: Microphone Recording Issue (on button down)
Fri May 24, 2013 7:06 pm
radi wrote: It was said many times, this is only a community forum, not a direct support line. If you are experiencing any problems with Mirillis software contact directly the support team via support@mirillis.com.
If that is the case, then you guys should seriously consider NOT having the FORUMS under the SUPPORT section of your webpage....it will not help saying in random topics that this forum is not a part of the support service with this!
sycoinc
PC Specification: win7, intel i7-3930k,Nvidia GForce GTX 6
Sat Jun 08, 2013 3:06 pm
Aullah wrote:GUYS GUYS!!! I MADE SOME PROGRESS. One thing is sure, it has nothing to do with sound driver.
So I tryed out the keys on my keyboard... and guess what. NONE OF THEM WORKED... Except HOME, DEL, END, PAGE UP, PAGE DOWN, 4 ARROW KEYS. Yea... Its effin weird... why they are working when "normal" buttons dont? So if you bind END as record microphone and set it to record on button down, it will work.
I have a wireless logitech keyboard so next step was to exclude that the problem is the wireless. I dig up my very oooooold wired keyboard. Same result. The wireless is not the problem. The problem is, that only these keys works as record microphone.
(Also, I just noticed the same goes for taking a screenshot. Del? YES WORKS, normal buttons? NO GO!)
sycoinc. Please confirm if this is applies to your problem too
Yes this worked for me, but when gaming moving all the way over that side of the keyboard is not useable since most games require the w,s,a,d keys to move.
this is the information their support team sent me after 2 weeks of not hearing from them from my initial support ticket
Please try following:
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again on freshly started system. Make sure that your installer file comes from
official website - http://www.mirillis.com.
After i did this, it still didn't work BUT the auto update started working again.... i messaged them back and have not heard from them since the 28th... their support system is rather lacking.
Mon Jun 10, 2013 9:07 am
sycoinc wrote:After i did this, it still didn't work BUT the auto update started working again.... i messaged them back and have not heard from them since the 28th... their support system is rather lacking.
Our support team is replying to every e-mail they receive. Send me a PM with your e-mail address and I'll check why you didn't received a reply.
HowardMack
PC Specification: Vishera FX 8320, 16Gb 2133, 7950, Win 7
Sat Nov 15, 2014 3:13 pm
I'm having the same issue, setting my button to the same buttons described fixes the record on button down for me. Current have mine set to END. The difference I'm having is when I set it to ALT on button down, it records all the time without even pushing button.
Fri Nov 21, 2014 1:07 pm
HowardMack wrote:I'm having the same issue, setting my button to the same buttons described fixes the record on button down for me. Current have mine set to END. The difference I'm having is when I set it to ALT on button down, it records all the time without even pushing button.
Do you use a regular keyboard?
HowardMack
Fri Nov 21, 2014 1:15 pm
Yes, it's a Dell keyboard model sk-8135, wired.
Mon Nov 24, 2014 6:03 pm
Does it have any special features like key mapping? There was previously a similar issue with Logitech gaming keyboard where the keys worked much more like a switch than a hotkey.
