cibergatox
PC Specification: i7 3770k 780ti 16gbram Win 7
Re: Action! 1.16.0 - 1.16.3
Fri Sep 27, 2013 7:01 pm
Hi I would like to suggest that Action! Saves my settings... What do I mean?
Well I usually switch my playback devices between my headset and surround system, and every time I go into Action! I usually record while using my headset, but if I've changed my playback devices this option changes and it doesn't revert in Action.. meaning I end up recording an audio device that is not playing anything...
What I want is Action! saving my selection and sticking up with it no matter what I do with my default playback device...
If this explanation was confusing, please tell me I would try to explain it better.
Thanks.
Javier
levi_120
PC Specification: Intel core i5,Gtx 560 ti,windows 7
Sat Sep 28, 2013 10:01 am
bug! i want get 60 FPS after recorder in MP4 but get only 30 FPS?! this is bug? :?
Sun Sep 29, 2013 9:13 am
Check if your settings from LIVE Tab does not overwrite your recording settings. If "Enable Action! LIVE Streaming" feature is ticked, this things may happen.
nikipatzi4
PC Specification: Intel Core I7, Nivida Geforce 560 Win 8
Wed Oct 23, 2013 7:38 am
I have a Problem with my Action
I can not exoirt any Video
I have reinstall the Program and some more
What can I do ??
Please help
Thanks
ciknapp
PC Specification: Windows 7
Wed Nov 20, 2013 1:00 am
Problem with trial version of Action. I don't know quite how to explain it, but when the Action window is even open it keeps making the window of my game (minecraft) deselected, which then pauses the game. It happens in every game, even in fullscreen. any help? :(
MgSolidus
PC Specification: win7/gtx1060/i5-3570/Z77SL-50K/16gbram
Wed Nov 27, 2013 2:47 pm
I play "Ghost recon online" and "Action" make single/multiple lag moments, and sound repeating.
Here is video, sound issue u can hear, multiple times, at first 2 minutes.
http://www.youtube.com/watch?v=vui4nRNofyE
Have stabil 60 fps, even with fraps(fraps never made any problems).
zerocool22
PC Specification: ASUS P8H77-V | i5-3570K 3.40Ghz (3.70Ghz
Fri Jan 03, 2014 5:23 pm
Hi i have a problem/suggestion, i made STREAMS with Action but the bad thing is when u are in game mode the program don't detect music let's say on winamp, on STREAM usually u mute the game audio and put music for do it more pleasurable. This happen in Local record to. And i already tried all the sound configs in Action.
i suppouse "music" is considered "system sounds" but it not get recorded and transmited in a Live STREAM neither (always talking about Game Mode), if i record or TRANSMIT the "Desktop" the music can be listen. Maybe ppl ddin't report this, cause i think not much ppl did STREAMS with Action Live yet or maybe this could be soemthing wrong wih the last version of the program? thx in advance.
Already trying Disabling "System Sounds" to but same result.
