zico
Re: Splash Lite, Windows 7 x64 and DVB-T
Mon Feb 01, 2010 6:46 pm
same problem for me..
great apps splashlite but with my tuner hauppauge nova-t stick and win7 x64 ultimate channel search do not function..it remains to 0% when start search (i select europe
i hope that the next version fix this problem..
Grunta
Tue Feb 09, 2010 12:33 pm
I installed some new drivers.
Still wont scan :(
adam777
Sat Feb 27, 2010 3:26 pm
I'm happy to report everything works perfectly in the new 1.3 version.
Keep up the good work! :)
qwerty
Sat Feb 27, 2010 3:50 pm
On my pc channel search work fine.
Thx mirillis. :)
Dorer
PC Specification: E6300 GF7600 Windows 7 x64
Sun Feb 28, 2010 8:17 pm
Thx guys!!
Helios
Sun Mar 07, 2010 8:09 pm
Thank you all for your feedback. I'm very happy it finally works.
Splash Lite is better and better thanks to your suggestions and feedback.
Thank you all again!
DGMurdockIII
PC Specification: AMD Phenom, ATI Radeon HD 4600 Win764bit
Sat Mar 13, 2010 8:09 pm
The TV dose not works with splash lite with my Tv Tuner.
TV Tuner vendor : ATI/AMD
TV Tuner Model : All-in-Wonder HD, Digital/Analog PCI Express 2.0
OS : Windows 7 64bit pro
DGMurdockIII
Mon Mar 15, 2010 4:39 pm
please check
Thu Mar 25, 2010 11:40 pm
DGMurdockIII wrote:The TV dose not works with splash lite with my Tv Tuner.
TV Tuner Model : t, Digital/Analog PCI Express 2.0
What is your location (Country)?
Splash Lite support only DVB-T at the moment. ATSC will be supported in the future.
dan92arg
PC Specification: Intel Core i7 Nvidia GT220 Windows 7 x64
Thu Apr 08, 2010 8:33 pm
The DVB-T doesn't works with splash lite with my Tv Tuner.
TV Tuner: Avermedia A815 Volar HD
OS : Windows 7 64bit Home Premium
Country: Spain
I've tried with the same tv tuner in this pc (Windows Vista x86 laptop) and it runs great.
