harveychestbreach
PC Specification: Windows 7 Pro, AMD A10-5800k, MSI R9 270
Re: Fixed Action! 1.25.0.0
Thu May 21, 2015 6:05 pm
Hey all I do have a temp fix until they update if this did not work for you! Well you see the download links for Action! are really simple! Just go to http://download.mirillis.com/files/acti ... _setup.exe replace the action_1_24_3 with whatever version you want! Hope this helps! :D
Thu May 21, 2015 7:35 pm
Fixed in new release (1.25.1)
Update here: https://mirillis.com/en/downloads/downloads_action.html
