Re: Action! Version 1.25.3.0 Not Loading
Fri Jul 17, 2015 8:11 am
AMD users with lower cards than 7700 may still suffer from startup failure due to the AMD drivers. We are working on a fix.
edit:
New Action 1.25.5 update with fixes for AMD card is now available to download. Recommended for all AMD users: http://bit.ly/ActionDownload
biggranny
PC Specification: Windows 7, AMD Phenom 965, r9 270x
Sun Jul 19, 2015 3:08 pm
radi wrote:AMD users with lower cards than 7700 may still suffer from startup failure due to the AMD drivers. We are working on a fix.
edit:
I can't install the new update for some reason (I am having the same problem of crashing on start-up with new AMD drivers.) I get this error: - screenshot http://puu.sh/j4TXU/0203eb85b4.jpg - Thanks for the help.
GEonWAR
PC Specification: FX8350, R9 290x, Windows 10 pro
Sun Jul 19, 2015 5:17 pm
edit:
I am using a higher card R9 290x and this worked for me thx.
