die Funktion LIVESTREAM buggt richtig rum. Manchmal hört es einfach auf zu Streamen und das Programm stürtzt ab... HELP!
It doesn't help. I have the same problem. It exist with SLI configuration. When I set in nVidia Control Panel to turn on SLI configuration then the recording crash at the end. When the SLI configuration is off then is no problem. But the point of having two or more GPU is that you are using them in SLI. I also have the newest version and the problem persist.radi wrote:Please update your Action to 1.27.0 and see if the same issue occurs:
https://mirillis.com/en/downloads/downloads_action.html
As far as I know SLI configurations are not supported, but I will have to verify this.zczachor wrote:It doesn't help. I have the same problem. It exist with SLI configuration. When I set in nVidia Control Panel to turn on SLI configuration then the recording crash at the end. When the SLI configuration is off then is no problem. But the point of having two or more GPU is that you are using them in SLI. I also have the newest version and the problem persist.radi wrote:Please update your Action to 1.27.0 and see if the same issue occurs:
Please fix that problem. I hope that I can use the program I paid for.
Regards.
That's not the point. It's not important if Action supports SLI or not (would be nice if it would). The point is that software shouldn't crash at the end of recording regardless if someone use SLI or not.radi wrote:As far as I know SLI configurations are not supported, but I will have to verify this.
I've been using Action in Windows 7 for well over a year in an SLI configuration (both 2-way and 3-way) without any issues. If Action didn't support SLI then this should be stated somewhere as people who have high-end computers want to be able to stream and record video, and not have to be gimped to a single GPU—Especially since UHD 4K is becoming more widely adopted, and isn't all that easy to drive on a single GPU.radi wrote:As far as I know SLI configurations are not supported, but I will have to verify this.
Users browsing this forum: No registered users and 47 guests
