aviwil
Re: Splash PRO 1.4.0
Mon Jan 10, 2011 3:55 pm
With Smartseek , when video track 2 is selected , it will show video track 1 .
nunatak
Tue Jan 11, 2011 5:06 am
I'm not sure if it's a new or old bug, but i can't disable external subtitles from the right-click menu, only from the subtitles icon.
icsterm
Contact: Yahoo Messenger
Tue Jan 11, 2011 1:19 pm
aviwil wrote:With Smartseek , when video track 2 is selected , it will show video track 1 .
I confirm this bug.
resinate
PC Specification: Win7 Ult
Thu Jan 13, 2011 10:24 am
is it just me or is the sound playback like 50% volume now? cuz almost all my movies now even at max volume now its very quiet compared to 1.3.3
lbamda
Tue Jan 18, 2011 6:24 am
Hello!
Bugs and requests for Splash PRO 1.4.0 :
Not support LPCM audio in mkv and DVD-video files (noise). (Win7) !!! :shock:
Not support pgs subtitles in mkv.
Not support chapter in mkv.
Not support name track in mkv (support only track language). !!!
Not support 4.0 audio-configuration (quadro)!!!
Not support DTS-HDMA and TrueHD decoding.
Incorrectly decodes 3.1 audiotracks for stereo audio-configuration (without center chanell).
And now about the good:
Best video and audio quality among all players :shock: .Especially perfectly well for me as audiophile quality of audio - the best player for Flac! Awesome player!
Re: Splash PRO 1.4.0 & 1.4.1
Tue Jan 18, 2011 3:32 pm
Splash PRO 1.4.1 is now available.
What's new in Splash PRO 1.4.0?
* IMPORTANT improvements for AVCHD authored media playback and AVCHD camcorder structure playback using interactive menus
* Improved rendering of PGS subtitles
* GUI improvements
Tue Jan 18, 2011 4:15 pm
Thanks all for your problems reporting and suggestions!
crl2007 wrote: 1. To be able to add multiple files at once in the playlist when you press Add File.
2. To be able to load a whole folder to the playlist. To drag and drop the folder in the playlist screen and the video files contained to show there.
3. To be able to load multiple folders to the playlist.
4. A kill switch for times when the player crashes. It does not shutdown completely and the video card can't go back to 2D clocks because it is still in use by the player.
5. For the player to permit screensaver and monitor shutdown when it is running but the film is on pause.
1. It is already supported, when you press "+" button on playlist. There is multi selection available.
2. It is also supported, but it does not include files in subfolders. Do you mean taht you want all files (also in subfolders) to be added to a playlist?
latino wrote:I looked in the manual but there still is no way to manually set the subtitle sync. So you always have to enter the menu, make a change and return to see the result, that really doesn't work. Is there no keyboard shortcut to achieve this?
At the moment no shortcut for this function but it will be added soon.
Sparhawk wrote:it looks rly great, but can u pls add feature which can save movie position when u exit splash, like MPC home cinema, vlc player etc have already? I think this is must have feature.
thx
It is supported through a playlists. All movies on playlists save movie position and you can resume a playback later with a special button on a playlist. Automatic movie playback resume will be also added soon.
icsterm wrote:
Joco1114 wrote:Please give us BOLD subtitles!
Yes, we should have bold subtitles :D
Bold and italics will be soon added.
tuvi123 wrote:You have to read this about splash:
http://www.mirillis.com/forum/viewtopic.php?f=18&t=598
some suggestions that will really help improving the player.
Hi, will reply to all suggestions in those thread later.
ney2x wrote:Please add support for WASAPI or Reclock. Thanks much!
This is not planned at the moment.
JCRUYFF wrote:Splash Pro GPU Support for Chipset Intel G41 (Intel GMA X4500)? if not plz add support
thanks!!!
It should work fine. Do you experience any problems with Intel G41?
Tue Jan 18, 2011 4:16 pm
bozo wrote:a two options to add:
1. Ability to exit splash after movie is finish or playlist finish.
2. Shutdown puter after movie is finish or playlist finish.
3. An osx version with acceleration on at least on GF8600GT
1. Shutting down, hibernating etc after finished playback is planned to be added in future versions of Splash,
but at the moment we do not know if it will be added in free updates or in next 2.x.x version of Splash PRO.
2. If you mean a Mac version. It is planned to be released but it is delayed and we do not know when it will be available.
crl2007 wrote:It would also be nice to be able to turn off the repeat function in the playlist. After a playlist finishes, it should not start all over again.
Sounds ok. Thanks.
Romich wrote:anyone else seen something like this? or is it just me?
Please check latest 1.4.1 version. It should be fixed.
nunatak wrote:New bug in Splash 1.4.0, i can't disable "Force Video Overlay".
Does it happen on Windows 7 and 9800GT? PLease try running Splash PRO Cleanstart from Splash PRO installation folder, please note it will reset your Splash settings.
Yes, it is a known bug.
nunatak wrote:I'm not sure if it's a new or old bug, but i can't disable external subtitles from the right-click menu, only from the subtitles icon.
At the moment this is done by design. External/internal subtitles managing will be improved in future versions.
resinate wrote:is it just me or is the sound playback like 50% volume now? cuz almost all my movies now even at max volume now its very quiet compared to 1.3.3
Please check if it repeats for all audio codecs (ac3, mp3, dts, lpcm etc) or only for a one specific codec.
lbamda wrote:...
PGS and chapters are not supported yet in mkv files. PGS should be soon added.
We will check out ssues with LPCM audio and 4.0 and 3.1 audio.
Software decoding of HD audio codecs is not planned to be added in this version of Splash PRO.
crl2007
Tue Jan 18, 2011 5:04 pm
Ghost wrote:Thanks all for your problems reporting and suggestions!
crl2007 wrote: 2. To be able to load a whole folder to the playlist. To drag and drop the folder in the playlist screen and the video files contained to show there.
I expressed that feature request a bit wrong. I was talking about selecting more folders and add them to the playlist with drag and drop. If you select one folder it adds the contents to the playlist, but if you select 2 folders it doesn't. And a subfolder feature would be nice too. :D
Splash viewer
PC Specification: hp quad win 7 ultimate
Tue Jan 18, 2011 7:54 pm
Found new bug
Enter en arrows key are disabled when playing avchd not when playing a file.
