krzychox
PC Specification: i5-3210M@2.50, HD Graphics 4000, Win10
Re: Users' Wishlist
Fri Dec 14, 2018 4:43 pm
What about stretched resolution? I don't have 1920x1080 screen and i play csgo in 4:3 stretched (1400x1050) and i'd be happy if you could stretch any resolution in action
Nonny
PC Specification: Intel i7 5960x, Nvidia Strix GTX1060
Re: Users' Wishlist
Tue Dec 18, 2018 1:21 am
Hello Forum :-) ,
yes i am new here ;-) , at first i would like to say i like the action recorder a lot and i use it sice ... hmmm ... well i belive version 1.29.0 and i like the way its processing ! good work !
i would like to mention some thing what i belive would be usefull too !
1. i would like an option for Webcam fading , like when i record a game and turn on the webcam its directly there , i would like to have an option i can aktivare a webcam "Fader" with the "Fader time"" like 0,5 secounds or 2 secounds .. would be nice so when i turn of my webcam durning gaming it dosent looks like the webcam crashed somehow :-D
2. i would like also maybe an option to export to local file for editing maybe later on and not like direct upload , like exporting and preparing to youtube but local and not straiht online sending ...
thanks a lot and keep up the great work
Nonny
EDIT: ... OH one more thing ! Is it possible to add maybe something like a "Recording Pfrofiles" , exapmple : .. i record a game with webcam and seperates mic track , after this i would like to recoud a "Video message" from "Device" (last source button on the right) - my webcam so i have to change the webcam settings lets say to a HD resolution ... all ok but when i what to record now an other game and forget the webcam settings so i have a huge webcam recording data but for just a little webcam image in the corner , maybe a "Recording Profile" can help .. "Profile Recording Video Message with my settings" , then "Game Profile recordings settings" maybe something like this ... :-)
AH ! AND please can i recourd also chose "Record webcam to seperate track *.MP4 " please, the webcam *.avi files getting bigger then the game itself :D
triggerboi
PC Specification: i5 6500, RX480 8GB, 16GB, Windows 10
Re: Users' Wishlist
Tue Dec 25, 2018 7:06 pm
I am still not able to stretch 1444x1080 or other resolutions than 1440x1080. Please, add this! :/ I started using other streaming software because of this and now the other software started lagging a lot, so I want to switch back to you but I still need to be able to stretch ANY resolution. Ty.
donedara
PC Specification: i5-7200U / GTX 950M / Win 10 Home x64
still lack of some key features even in pro version!
Sat Dec 29, 2018 4:27 am
** Splash 2.2.0.0 **
lacks of these keyfeatures....
1. keyboard shortcut, i can't customize keyboard mapping for any action
2. there is no filter settings in video mode (brightness,color saturation,contrast,...)
:evil: :evil:
sparxx
PC Specification: 1080 i7 windows 10
Changing Webcam Positioning Between Overlays
Sun Dec 30, 2018 4:11 am
Hi all,
Just wondering if you can change the webcam positioning instantly between changing your overlays? like obs does with its scenes,
Thankyou for your help in advance.
Sparxx.
Darkiyus
PC Specification: Ryzen 9 5950X, 3090, Windows 10
Re: Users' Wishlist
Sat Jan 05, 2019 6:50 pm
Mode: Live Stream
Function: Overlay sources | URL
Idea:
It would be nice, if one reads out a text file, that one can adjust the text color etc ...
This would be good for the Snaz program, for example, which creates a countdown (for a 24 hour stream, for example) via a text file.
Idea 2:
I wish that you finally get the size of the window of Action! can adjust.
Solarjetman
PC Specification: Canada
Color correction during recording filter
Sat Jan 05, 2019 10:04 pm
Come on Mirillis, please add a way to saturate game recording live, saturating video in post takes way too much time.
Specially if you have a 60min game gameplay.
You can currently do it with certain kind of graphic cards, it would be a great advantage to have live color correction in Action Recorder.
Some screen capture recorder have it but they take way too many resources from the CPU and the graphics card.
Claunator
Re: Users' Wishlist
Fri Jan 25, 2019 5:57 pm
PERFECT!
V-Meatsac-V
PC Specification: 8700K - 32GB of ram - GTX 1080-Win10pro
Re: Users' Wishlist
Mon Feb 04, 2019 4:17 am
Greetings,
There are a few features I would love to see added to Action (adding these would be greatly appreciated)
(1). The ability to use transparent PNG images for overlays for live streaming. Currently Action doesn't support transparencies, it would make life alot easier.
(2). Ability to scale the live feed (kinda like you can scale overlays).
(3). Chroma Green (or selected color) removal for live stream Overlays.
bp1
PC Specification: i7 6850k, GTX 1080ti, 32 GB DDR4 Ram
100 Mbps bitrate is not enough.
Fri Feb 22, 2019 5:38 am
I just purchased this great software. I come from OBS and Dxtory, and I love how compatible Action is, tested it on over 10 games with no problem. I do 4k recording and I think 100 Mbps on mp4 is way too low, I'm not getting enough information on my footage, too many artifacts. Please give us the option to at least bring it up to 200 Mbps. Please!
Thank you!
bp1
