mata
PC Specification: Ryzen7 2700, 16GB, RX 580 4GB, W10 v2004
Re: FIC Decoder DirectShow - BETA!
Sun Jun 24, 2012 8:52 am
Just popped in to report that after installing the decoder the thumbnails work, MPC HC can play the video, but not the audio (5.1), I also wasn't able to load the .fic files in StaxRip (perhaps that is not the decoders problem) - still, appreciate the effort, keep it coming! ^^
RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Tue Jun 26, 2012 9:57 am
Action! 1.5 FIC:
Don't know how to embed youtube video on this forum :\
http://www.youtube.com/watch?v=YoUpiEIV_Jc
The recordings are made with multi-channel disabled.
As you can see, WMP was unable to open the gameplay file but was able to play the desktop recording.
WLMM was able to import the fic files but there was no audio (+tested with multi-channel turned on).
Adobe Premiere CS6 was unable to to anything.
Tue Jun 26, 2012 11:06 am
mata wrote:Just popped in to report that after installing the decoder the thumbnails work, MPC HC can play the video, but not the audio (5.1), I also wasn't able to load the .fic files in StaxRip (perhaps that is not the decoders problem) - still, appreciate the effort, keep it coming! ^^
Please update to the latest Action 1.5.0 version and check if problems with audio are solved.
RazrBit wrote:Action! 1.5 FIC:
Thank you very much for detailed report and the video showing all problems.
We are still working to solve problems with WLMM (no audio), Premiere and few other appliactions.
Our next step is to introduce avi format as this should solve all problems with software comapitibility.
About problem with game recordings playback in WMP:
- Have you experienced this problem with beta version of FIC decoder?
- Do you have problem with old recordings only? I mean if you make brand new recording does it reproduce the problem or works fine?
- Can you please check if playback works fine with other players than WMP?
RazrBit
Tue Jun 26, 2012 12:04 pm
Ghost wrote: - Have you experienced this problem with beta version of FIC decoder?
Yes, don't know why I forgot to mention it.
Ghost wrote: - Do you have problem with old recordings only? I mean if you make brand new recording does it reproduce the problem or works fine?
These recordings were made with v1.5 (in video), the problem also exists with older recordings.
Ghost wrote: - Can you please check if playback works fine with other players than WMP?
Other players are able to play it without any problems.
The problem only exists when trying to play the recorded gameplay with 32bit version of WMP. 64bit WMP works fine.
ObserverJLin
Thu Jun 28, 2012 5:14 pm
Watchman wrote:Have you been trying to import raw Action! recordings (.fic) without installing the DirectShow decoder? What do you mean by "Failed". Windows Movie Maker works 100%, also no problems with Adobe Director in our labs. We are verifying other third party software for problems.
Yes I tried to import raw MA! recordings into Pr CS6 without installing DirectShow decoder.
Can you plz explian how DirectShow decoder works and where can I download it?
ObserverJLin
Thu Jun 28, 2012 5:33 pm
Do I need internet to activate decoder?
mata
Sat Jul 07, 2012 7:07 am
Did that, and now there is sound, too. MPC-HC plays the files flawlessly. Also, StaxRip was able to load up the .FIC files, so now I can encode it with any setting I would like :) The only remaining problem is extracting the audio track from the .fic file, but that won't be a problem for too long (hopefully) as you have said you are working on implementing recording into .avi
Thanks for your great work!
Thu Jul 12, 2012 2:23 pm
Hi, guys.
In 1.6.0 version we will switch recording to avi format and release Video for Windows decoders.
We have checked it so far with following editing software (with all works fine):
Adobe After Effects CS5
Adobe After Effects CS6
Adobe Premiere Pro CS6
Sony Vegas PRO 10
Sony Vegas PRO 11
VirtualDub
Windows Live Movie Maker
Cyberlink Power Director 10
MAGIX Video Pro X4
Camtasia Studio 7
Camtasia Studio 8
denon480
PC Specification: Core i5 2500k, HD6970 Windows 7
Thu Jul 12, 2012 4:43 pm
Good news,realy good news,thank you for best of the best recorder))))
colew
PC Specification: Core 2 Duo, HD 6670, Windows 7 Ultimate
Tue Aug 07, 2012 7:35 pm
I have Action! 1.6.1. I recorded a 37 minutes of video in 4 part. (pauses)
I tried to edit it in PowerDirector 10.0 and its showed this:
An error eccurred while opening this media file in the media library. It may be because the file is broken, an unsupported format, protected video content, or for another reason. Try contacting your video provider for a different video format.
[video location]
I'm installed this Decoder, and it's isn't working too.
What would I do?
