Re: ACTION! 1.12.0 & 1.12.1 & 1.12.2
Tue Feb 05, 2013 10:45 am
Thanks for the latest suggestions guys. I've added them to our wishlist.
MrT
PC Specification: i7 920, Palit GTX275, Windows 7 x64
Tue Feb 05, 2013 10:52 am
All hail Action! I wish you all the best in developements such a awesome software!
JulioCesarSF
PC Specification: Core i7 3770k, SLI GTX 680 Lightning
Mon Feb 11, 2013 1:02 pm
HOw to create a table with benchmark file? :?:
daniel44
Tue Feb 12, 2013 3:02 pm
SysL wrote:turn off the computer file export process?I hope that is such a feature in the new version.
i don't think it can be done.
Action! records files to .fic file. when you record to a .fic file you don't need that much power from your computer to record so that's what gives you the ability to record smoothly with Action! ulike fraps that records the file directly to .AVI which takes a lot of power from your computer so you have fps drops very often, also fraps seperates the video to a number of files which weight a lot!
