qwerty
Re: 24 Bugs and Enhancements
Sun Oct 02, 2011 7:34 am
VLC work fine with this sample file.
P.J
Mon Oct 03, 2011 7:51 pm
What about if you remux it with MKVToolnix? :?
ocd
Tue Oct 04, 2011 8:30 am
Remuxed it and had to add the Subtitle INTO the MKV file and then Play it with Splash and now it works. But why does it not work when the subtitle is External SRT file? What gives? It loads but shows nothing.
P.J
Tue Oct 04, 2011 6:21 pm
But the file you sent it here had embedded subtitle tracks and didn't work in Splash :?
lluvia
PC Specification: Intel, NVIDIA, W7
Sun Jan 22, 2012 2:01 pm
qwerty wrote:Fix some subtitles problem. I have mkv file and this file have 19 subtitle track. Here is sample:
http://www.mirrorcreator.com/files/CHG3 ... .mkv_links
Splash lite and pro doesn't show any available subtitle track.
Thanks, we will investigate this problem.
ocd wrote:Subtitle Issue here as well.
Got Serenity English translation to Chinese/Russian, converted it into UTF-8, TV plays it, Splash loads its but doesn't show anything on screen. Very weird. Its all standard. But No show.
Can you please send us sample sub file for investigation?
General Forum Support
Return to “General Topics”
