and how will your graphic card behave without any driver?latino wrote:I fixed my problem....I reinstalled Windows and now it worked. I did NOT install any ATI drivers, so I guess the problem is to be found in these drivers. Although uninstalling them didn't help at all....
I also coudn't find a logfile anywhere on my system btw.
Maybe you could alter the startup somehow in the next version to be able to report the error in a better way?
wow that worked... here's log file content:Helios wrote:Hi Obazu,
unfortunately we can not reproduce the problem on none of our mashines, but we do want to fix it if possible.
If the directory does not exist, it means there is a problem with users rights to the directory.
Could you please make a test for us, and create the directory manually?
C:\Documents and Settings\MYUSERNAME\Local Settings\Application Data\Mirillis
then run
C:\Program Files\Mirillis\Splash Lite\Splash Lite CleanStart
and look for the log file again?
Code: Select all
[SplashLog]
CP01=0x0000
CP02=0x0001
CP03=0x0002
CP04=0x0003
CP05=0x0004
It uses the standard driver that came with Win7NumB wrote:and how will your graphic card behave without any driver?latino wrote:I fixed my problem....I reinstalled Windows and now it worked. I did NOT install any ATI drivers, so I guess the problem is to be found in these drivers. Although uninstalling them didn't help at all....
We are discusing the log you send and trying to figure out where the problem is.NumB wrote:any info?
