Joco1114
Re: Splash PRO 1.4.0 & 1.4.1
Wed Jan 19, 2011 7:04 am
Thank you for improving my favorite player, but here are some ideas you missed:
* play next file in NAME order (please, please!)
* hotkeys (prev/next audio track, prev/next subtitle, subtitle sync, etc.)
* command line extensions (assing all video files to Splash, save-restore config settings, silent install, etc.)
Joc
Home Theater:
Synology NAS 1010+ | 9TB HDD
Thu Jan 20, 2011 10:15 am
Joco1114 wrote:Thank you for improving my favorite player, but here are some ideas you missed:
Joc
Available at the moment:
a - next audio track
z - next subtitle (internal) track
More shorcuts will be soon available.
Restoring settings is available through Splash PRO Cleanstart from Splash PRO installation folder.
Playing next file in name order is on our list, but somewhere at the bottom.
At the moment playing order is based on Windows functions that return next file in folder.
Thu Jan 20, 2011 10:27 am
Joco: what's your file system on disk where you experience problem with nextfile order? is it fat32 or ntfs?
monkeyman
PC Specification: Pretty good one.
Contact: ICQ Website
Thu Jan 20, 2011 10:48 am
nunatak wrote:I'm not sure if it's a new or old bug, but i can't disable external subtitles from the right-click menu, only from the subtitles icon.
I already saw the developers' answer to this and just want to add my voice. It's pretty annoying, that to just turn on/off external subtitles you have to enter Settings. Hope this will be fixed.
Thu Jan 20, 2011 11:27 am
monkeyman wrote: I already saw the developers' answer to this and just want to add my voice. It's pretty annoying, that to just turn on/off external subtitles you have to enter Settings. Hope this will be fixed.
You can easily disable/enable external subtitle with one click on icon on control panel.
The problem nunatak reports is that disabling external subtitles in not available through right mouse button menu.
Joco1114
Thu Jan 20, 2011 4:46 pm
NTFS. Nextfile means how the Windows serve the files. ("unsorted"?) If I copy the files in this order: episode 3, episode 2, episode, 4, episode 1, Splash will play file in this order, not the "natural" (1,2,3,4) order. I miss this feature.
Ghost wrote:Joco: what's your file system on disk where you experience problem with nextfile order? is it fat32 or ntfs?
Home Theater:
Gunhed
PC Specification: Pentium 4, 2gb, intel extreme
Thu Jan 20, 2011 10:07 pm
I bought a new laptop, Lenovo edge 13 which has Intel ulv 1.3 ghz cpu and Intel Gma 4500 graphics chip. I played a fullHD clip without picture 2 engaged. The GPU symbol was shown on the player but the playback was very slightly jerky. I played the same clip with the windows 7 media player and the video was smooth. Any reason for this ?
mickeekung
PC Specification: XP SP3 Core2Duo E7300@2.66 2GB 9400GT
Sat Jan 22, 2011 9:24 am
Found new bug in Splash Pro 1.4.1.
When I open wmv mp3 and asf file.Nothing happen.
icsterm
Contact: Yahoo Messenger
Mon Jan 24, 2011 3:22 am
Gunhed wrote:I bought a new laptop, Lenovo edge 13 which has Intel ulv 1.3 ghz cpu and Intel Gma 4500 graphics chip. I played a fullHD clip without picture 2 engaged. The GPU symbol was shown on the player but the playback was very slightly jerky. I played the same clip with the windows 7 media player and the video was smooth. Any reason for this ?
i think gma 4500 (non HD version) supports mpeg4 acceleration and not H.264. Check your GPU specs. Also make sure you sure vista or 7 and latest drivers. HW acceleration on intel is not working on xp.
luca146
PC Specification: Phenom ii 4x955 nvidia gts 250 seven644c
Mon Jan 24, 2011 11:42 am
Thank you for your excellent player. Splash Pro uses Cuda cores? And so a GPU like an nvidia Gts 250 i better then a 9400 to help CPU load with motion2 enabled ?
