ionutph
PC Specification: Intel I5 2500K, 560 Ti, 4Gb XP SP3
Re: Splash PRO 1.13.0 - 1.13.2
Wed Mar 20, 2013 9:25 am
My only wish is to have adjustable font size for subtitles.
Summer Wind
PC Specification: i5-2410M, Intel HD3000 + GeForce 525GT
Wed Apr 03, 2013 5:47 am
Splash PRO 1.13.2
mkv with DolbyTrue HD track - no sound. Tested many files. Bug?
Thu Apr 04, 2013 10:37 am
Summer Wind wrote:Splash PRO 1.13.2
Is it possible that you could send us a sample file?
artoist
PC Specification: E8400,GTX285,Vista 64bit,Xonar ST,Z-5450
Thu Feb 13, 2014 4:13 pm
When suport for 4k stuff /mp4 /youtube codec 2160p/, mkv... :)
ex:
http://www.youtube.com/watch?v=gBabKoHSErI
reg
art
Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Fri Aug 15, 2014 1:54 am
Any word on an update or something? I'm finding weird issues.
Splash PRO freezing and forced to close.
Not being able to play certain .avi files or .mp3s
And some other weird things. It's been over a year - I think it's due. I do understand that Action! is your main product, but far out, I actually paid for PRO. Actually paid and no updates. :\ Sad panda is sad.
Splash PRO
SlayeCohenX
PC Specification: AMD FX 8350, GTX 760 SLI, Windows 8.1
Sun Nov 23, 2014 12:51 am
I barely use this player because i HATE those black bars, and anything below 1920x1080 has black bars in it, every other player i have i can change that and stretch as i like, but i love the 60fps instead of the usual 24fps, and the video quality is pretty good when you use the "Detail boost", so if you guys could just add an option where i can stretch and remove those annoying black bars i would be very pleased... ;)
Akura
PC Specification: Xeon1231v3,ASUS GTX960 4GB,Win7x64, 32GB
Thu Dec 25, 2014 2:10 am
double...
Akura
Thu Dec 25, 2014 2:11 am
Doesn't Play in mkv, but in Original m2ts Blu-ray File. ;)
Bug Report:
Don't know if it already exists...
Tried to play a converted TrueHD 7.1 24bit to FLAC file (with Audiomuxer or HD-BR-StreamExtractor) in an MKV, but only get a destroyed (flickering unclear) Sound?! Why? :( (No Problems with FLAC 5.1 and 16bit.)
I also already updated the FLAC dll File to 1.3.1 by my own. (libFLAC_dynamic.dll)
It doesn't matter, if with the original or new File, still got the same error.
Please fix this...
Edit: Was my fail, because of some error with Shark007 Codec Pack so it seems. Everything's fine now with FLAC 7.1 Sound.
Regards... :)
komayyamok
PC Specification: i3, intel, windows 10
Sat Aug 11, 2018 8:33 am
Splash viewer wrote:
Wed Aug 29, 2012 1:32 pm
Found a little bug in 1.13.0
When saving a still capture from a dvd (mpeg2) file which has the 16:9 marker set (widescreen)
The saved image is 720x(480,576) 4:3 instead of 1024x(480,576) 16:9
That was not making though 1.3.0.1
