Montago
Re: slight micro-stutter / judder @ 30 fps recording
Mon Apr 29, 2013 5:04 am
flashmp3 wrote:While i'm thinking of it just to mention that on my laptop, i tried to record on a usb3.0 usb flash drive and it was stuttering. When i changed to record it on the SSD no stutter anymore. The usb flash drive was bottlenecking the rest.
It sounds weird to me as it can write @20mo/s
USB require a ton of CPU to work and has a high latency, which all causes the program to slow down to sync the datastream...
amak1
PC Specification: I7 3770k, gigabyte gtx 680, win 7 home64
Sat May 04, 2013 11:39 pm
Im getting stutter at 1080p 30fps capture with quicksynch on playback. I cant get 60fps to work at all the playback just freezes. I will try another hdd or an ssd to see if thats the problem then i will try that valumvp thing listed here as my mobo supports it.
The system is i7 3770k, gigabyte gtx 680, 8gb ram , 1tb seagate hdd, 120 gb samsung ssd, windows 7 64 home premium.
celosdedma
PC Specification: Lenovo Y500 SLI
Thu May 09, 2013 6:21 am
I've been doing some tests with the new version 1.14 and the stuttering behavior changed.
In this new version, it stutters all the time when I record a game that's running in full screen (dx/opengl mode). It doesn't matter what the settings are.
But if I record the game that's running in windowed mode (still dx/opengl) it doesn't stutter anymore. Exactly the same settings and resolution as the full screen. This is an odd behavior.
Why is this happening? It's irritating if I have to run in windowed mode just for recording purposes. :(
I hope this gets fixed.
I know for a fact that my computer is highly capable of achieving this.
My computer is a lenovo y500.
2x GT 650M SLI
Core i7 3630QM
256GB Crucial M4 msata SSD
1 TB Crucial M500 sata SSD
Thu May 09, 2013 11:31 am
celosdedma wrote:I've been doing some tests with the new version 1.14 and the stuttering behavior changed.
2x GT 650M SLI
Core i7 3630QM
Have you tried recording to lower resolution like 720p? Or changing game resolution to 720p?
celosdedma
Thu May 09, 2013 2:49 pm
2x GT 650M SLI
Core i7 3630QM
Yes I have. I've been trying out all the options.
AVI mode is the one I use since Quick Sync is unavailable for my system. HD4000 is disabled by the manufacturer.
celosdedma
Mon May 13, 2013 5:01 am
I have verified that this stuttering happens on my system when I am recording a game running at full screen. No matter what resolution. When I run the game in the same resolution in a window, the stuttering disappears. I've just been running my games at 1920x1080 borderless window to compensate for this. it's just like running the game in fullscreen.
