Rikudou
PC Specification: Windows 7
Re: Action! 1.14.0 with webcams recording
Wed May 22, 2013 10:57 pm
radi wrote:Does the webcam record with MP4 mode for any of you?
Neither AVI or MP4
DJJoeJoe
PC Specification: Windows 8 64bit | CPU Q9300 | GPU 560
Wed May 22, 2013 11:16 pm
Hey, the webcam works when using mp4 mode, hopefully that helps to diagnose a possible solution! It's too bad mp4 mode is useless, who wants to record a 480p only video?
Thu May 23, 2013 8:56 am
DJJoeJoe wrote:Hey, the webcam works when using mp4 mode, hopefully that helps to diagnose a possible solution! It's too bad mp4 mode is useless, who wants to record a 480p only video?
MP4 records up to Full HD with Intel Quick Sync technology support.
If MP4 recording works for you uninstall Action! with registry cleaning. Reboot your PC (make sure that not any video application is not running) install Action! again.
misterK
PC Specification: windows 7, intel core 2
Thu May 23, 2013 4:02 pm
mP4 works for me :)
EDIT : I did the tips and it worked with avi :) thank you very much
Darktronik
PC Specification: Intel i5 2500, nVidia 660, Win 8 64-bit
Mon May 27, 2013 12:05 am
im having a problem: i can record with my webcam while playing a game, but there is no sound on it.
It has sound when i record without my webcam (video). Sound from game and from the mic works fine.
But i need to record with my webcam showing me.
Any tips?
DJJoeJoe
Mon May 27, 2013 6:18 am
Ok. I'll do that again I guess, I should note that I already did that though...
I'll go out and buy a new CPU as well, since that's also what you're suggesting?
Tue May 28, 2013 12:34 pm
If you would like to record with MP4 in Full HD we would recommend 2nd or 3rd Intel generation processor. Before you do this please make sure that your motherboard is supporting integrated graphics. http://ark.intel.com/#DesktopProcessors
Before you are installing Action! again make sure that there's no video application running on your PC that may interrupt Action! codec update.
Re: Action! 1.14.0-1.14.2 with webcams recording
Wed May 29, 2013 2:41 pm
New Action! 1.14.2 update is now available!
Change list:
* Fixed corrupted decoding of video recordings including specific mouse cursors (i.e. Photoshop CS6 recordings)
Karpiu93
PC Specification: Windows 7 GTX 560
Thu May 30, 2013 9:15 am
Not working for me. MP4 is working with my webcam, but i need AVI. I did this what u say four times and still nothing. I think any video application wasn't running. Help please.
Laurent13
Thu May 30, 2013 4:15 pm
Ghost wrote:New Action! 1.14.2 update is now available!
Change list:
Update updated 8-) I love you Mirillis team !!
