Obazu
PC Specification: AMD Athlon XP2400+ ATI Radeon HD3650
Re: Splash Lite crash on startup
Sat Jun 26, 2010 6:29 pm
Thank you for trying to help. I created the folder named Mirillis and yes, it creates the log file. It is excactly the same as NumB wrote.
I installed Splash Lite on our laptop and it worked without problems!
Specs:
HP 6715s
AMD Sempron 3800+
1 GB RAM
Ati Mobility Radeon X1250
It has also Windows XP Professional, it is installed from the same CD and it also has Service Pack 3. Both computers have all latest hotfixes from Microsoft.
But the laptop is my girlfriends so it doesn't help me much ;)
NumB
Tue Jun 29, 2010 4:56 pm
Helios wrote: We are discusing the log you send and trying to figure out where the problem is.
ok... i'll wait for a solution...
andresv
Fri Jul 02, 2010 9:06 pm
I have same issue. Machine is AMD athlon 2500+, graphics is asus hd3450
Code: Select all
[SplashLog]
CP01=0x0000
CP02=0x0001
CP03=0x0002
CP04=0x0003
CP05=0x0004
Also I have visual studio 2008 installed so here comes some extra info
Code: Select all
Unhandled exception at 0x00419d94 in SplashLite.exe: 0xC000001D: Illegal Instruction.
call stack
Code: Select all
>	SplashLite.exe!00419d94()
 	[Frames below may be incorrect and/or missing, no symbols loaded for SplashLite.exe]
 	msvcr90.dll!78583db8()
 	msvcr90.dll!78544267()
 	msvcr90.dll!78542775()
 	SplashLite.exe!0045e846()
 	SplashLite.exe!00486296()
 	SplashLite.exe!0045e9ab()
 	kernel32.dll!7c816fd7()
 	SplashLite.exe!00530057()
disassembly
Code: Select all
00419D7B  xor         eax,esp
00419D7D  mov         dword ptr [esp+1E8h],eax
00419D84  push        11Ch
00419D89  pxor        xmm0,xmm0
00419D8D  lea         eax,[esp+30h]
00419D91  push        0
00419D93  push        eax
*>00419D94  movq        mmword ptr [esp+10h],xmm0
00419D9A  movq        mmword ptr [esp+18h],xmm0
00419DA0  movq        mmword ptr [esp+20h],xmm0
00419DA6  movq        mmword ptr [esp+28h],xmm0
00419DAC  mov         dword ptr [esp+30h],0
00419DB4  call        0047D232
00419DB9  add         esp,0Ch
00419DBC  lea         ecx,[esp+2Ch]
00419DC0  push        ecx
00419DC1  mov         dword ptr [esp+30h],11Ch
00419DC9  call        dword ptr ds:[48715Ch]
00419DCF  test        eax,eax
NumB
Tue Jul 06, 2010 11:52 am
any solution found??
claus_S
PC Specification: sempron 2500 sk 462 Ati 3650HD, XP Sp 3
Wed Jul 14, 2010 10:25 am
Will be in the future a Splash lite version that will not require A processor that has SEE2 instruction set?
Blackspur
PC Specification: AMD Phenom Quad Core Nvidia GTS250
Tue Jul 20, 2010 7:38 pm
Well, I've got SP3 and a Quad core machine and an extremely fast video card and lots of memory and it crashes everytime on startup.
vkr
PC Specification: Pentium4-2.4 GHz, 512mb RAM, XP Home SP3
Thu Jul 22, 2010 4:52 pm
Splash lite 1.4 crashes as soon as i run it.
- Config - Intel Pentium 4 2.4 GhZ, 512 MB RAM, WIN XP Home edition SP3
- Tried reinstalling it (as admin) - still crashes
Log file below...
[SplashLog]
CP01=0x0000
CP02=0x0001
CP03=0x0002
CP04=0x0003
CP05=0x0004
CP06=0x0005
CP07=0x0006
CP08=0x0007
CP09=0x0009
CP10=0x0008
CP11=0x0010
CP12=0x0011
Any solution so far?
gone09
PC Specification: XP
Thu Aug 26, 2010 5:50 am
Hello.It is sure that you are not having problems with your antivirus?I advice to change it or to get another version.http://www.best-antivirus.co/ may help you with some reviews of the best antiviruses
good luck
Obazu
Tue Sep 21, 2010 10:41 pm
I tried the new version Splash Lite 1.5.0 and same problem still... So nothing has changed!
maryjuanca
PC Specification: ATHLON XP 2500, ATI HD3450, XP SP3,
Wed Sep 22, 2010 10:00 am
Hi, sorry for my language. I am Spanish and my English is limited.
I Have Tried Lite Splash 1.2, 1.3, 1.4, 1.4.2, 1.4.3 and 1.5.0 and none of them has ever even start on my system.
CPU: AMD Athlon XP2400 +
GPU: ATI Radeon HD 3450 AGP drivers with newest 10.06
RAM: 1.5 GB memory
Windows XP Professional with SP3
I do not get it working. (It works perfectly on two other computers.)
Suspect:
Chipset motherboard (Asrock K7VT4A PRO).
Power supply. I'm about to change. It will report on the matter.
I can not think of anything more ........
If someone finds a solution, please communicate.
Thank you very much!!
