EvertonMonkey
PC Specification: Core i3-330M, Intel HD Graphics, Win7x64
Re: Splash PRO 1.7.0 & 1.7.1
Sun May 29, 2011 11:36 pm
Since updating to 1.7.1 I seem to be having a similar problem to what I had in 1.3.2 using a core i3-330M Intel HD Graphics, the video is not jerky and not smooth, although enabling video overlay seems to fix the issues. Below is the quote of my previous post problems from the other thread :
EvertonMonkey wrote:
EmZvr wrote:I have a problem with thelatest version 1.3.2. I'm using the Intel HD video card integrated in Core i5 and when VIdeo overlay is disabled all the movies I play have a huge lag. When enabling video overlay everything is okay but every time I run Splash Pro it changes my theme to WIndows 7 Basic.
I installed the old version and without video overlay I can play every movie without problems.
I'm having the exact same problem on my Core i3-330M, Intel HD Graphics system. Worked perfectly before the update and is jerky a hard to watch with the update. Video overlay makes it better, but also makes the windows basic graphics profile activate. Please help.
And the URL : http://www.mirillis.com/forum/viewtopic ... 2610#p2610
Thu Aug 11, 2011 12:13 am
razor wrote:Which are "Command line improvements" in Pro 1.7.1 ?
Some directory handling problems fixed.
amhsby wrote:in the future, can splashpro added video format extensions .tp
coz my MV n PV korean pop with .tp extensions
i like your detail n light boost
i hope this extensions .tp works for the next splashpro version
Should be added in 1.11.
dmitry4er wrote:Are you planning to support 3d in this player? It would be nice to see 3d files (at least stereo pairs - OverUnder and SideBySide) on 3dtv. Today i can do it with some other media players, but all of them works so slowly (in different to this one)...
3D is planned for future versions.
EvertonMonkey wrote:Since updating to 1.7.1 I seem to be having a similar problem to what I had in 1.3.2 using a core i3-330M Intel HD Graphics, the video is not jerky and not smooth, although enabling video overlay seems to fix the issues. Below is the quote of my previous post problems from the other thread :
There should be no changes in Splash that cause the prolem to appear again. Do you have all basic video controls in playback options reset?
Do you use any Picture2 enhancements?
P.J
Wed Aug 17, 2011 10:33 pm
It should be fine with Aero and no need to enable Overlay.
Check your graphic memory usage with GPU-Z. Aero takes more VRAM.
Have you tried Basic theme without Overlay too?
Can you set the shared video memory? Because it uses your main memory (RAM)
